Hello. I’m using home assistant whit an Aeotec 7 usb stick and I have a small problem. Using the Z-Wave JS add on, but every time I try to add new plug, sensors they’re added unsecure, the thing that I use suport S2 security, how can I fix it?
First we need logs to tell for sure.
Second. What is the device (model number matters)
Third unless the device is participating in a security system you may not need secure connectivity.
Finally how many other ZWave devices are between your device and the coordinator (stick) and are they battery or line powered devices?
