Need to create multiple custom sensors with parameters
Hi Everybody,
I created a custom sensor which lets me know if I can go to work by bike by analyzing the rain, temperature and pollution on my route. It generate a score for today. (It relies on the open meteo API)
I would like to see the index for today and tomorrow.
I need to produce this sensor in 2 versions: one for today and one for tomorrow.
How to create 2 sensors with date as parameter?
file : init.py
"""Example Load Platform integration."""
from __future__ import annotations
from homeassistant.core import (
    HomeAssistant,
    ServiceCall,
    ServiceResponse,
    SupportsResponse,
from homeassistant.helpers.typing import ConfigType
from datetime import datetime, timedelta
import logging
from urllib.request import urlopen
import json
DOMAIN = "ready_to_bike"
# seuils
DATE_OF_THE_DAY = datetime.now().strftime("%Y-%m-%d")
APPARENT_TEMPERATURE_THRESHOLD_MORNING = 23
APPARENT_TEMPERATURE_THRESHOLD_EVENING = 27
PRECIPITATION_PROBABILITY = 10
PRECIPITATION = 0.1
EUROPEAN_AQI = 41
US_AQI = 51
DEFAULT_CONF_UPDATE_INTERVAL = 1
HOUR = [7, 8, 17, 18]
CITIES = {}
CITIES["Bry-sur-marne"] = [48.8381, 2.5249]
CITIES["Nogent-sur-marne"] = [48.8367, 2.4825]
CITIES["Vincennes"] = [48.8486, 2.4377]
CITIES["Paris"] = [48.8534, 2.3488]
_LOGGER = logging.getLogger(__name__)
async def async_setup(hass: HomeAssistant, config: ConfigType) -> bool:
    """Your controller/hub specific code."""
    _LOGGER.info("Setup Ready To Bike ")
    date_of_the_day = datetime.now().strftime("%Y-%m-%d")
    # Data that you want to share with your platforms
    hass.data[DOMAIN] = {}
    async def call_open_meteo_api(call: ServiceCall) -> ServiceResponse:
        return_of_call = await async_call_open_meteo()
        return {"return": return_of_call}
    async def async_call_open_meteo():
        _LOGGER.info("Call API ")
        hass.data[DOMAIN]["state"] = []
        data = {}
        for hour in HOUR:
            data[hour] = {"hour": 0, "super_indice": True, "data": {}}
            for city in CITIES:
                data[hour]["data"][city] = {}
        super_indice = {}
        for hour_index in range(25):
            super_indice[hour_index] = 1
        for city in CITIES:
            _LOGGER.info("Loop " + city)
            meteo_result = await fetch_weather_data(hass, date_of_the_day, CITIES[city])
            air_result = await fetch_air_quality_data(
            for hour in HOUR:
                array_of_data = []
                # calcul des seuils
                if hour < 10:
                    apparent_temperature = (
                        meteo_result["apparent_temperature"][hour]
                        < APPARENT_TEMPERATURE_THRESHOLD_MORNING
                else:
                        < APPARENT_TEMPERATURE_THRESHOLD_EVENING
                precipitation_probability = (
                    meteo_result["precipitation_probability"][hour]
                    < PRECIPITATION_PROBABILITY
                precipitation = meteo_result["precipitation"][hour] < PRECIPITATION
                european_aqi = air_result["european_aqi"][hour] < EUROPEAN_AQI
                us_aqi = air_result["us_aqi"][hour] < US_AQI
                # Calcul de l'indice en fonction des conditions spécifiées
                indice = (
                    and precipitation_probability
                    and precipitation
                    and european_aqi
                    and us_aqi
                # Calcul du super indice
                super_indice[hour] = indice and super_indice[hour]
                hass.data[DOMAIN]["state"].append(super_indice[hour])
                data[hour]["hour"] = hour
                data[hour]["super_indice"] = super_indice[hour]
                data[hour]["data"][city]["indice"] = indice
                data[hour]["data"][city]["city"] = city
                data[hour]["data"][city]["apparent_temperature"] = meteo_result[
                ][hour]
                data[hour]["data"][city]["precipitation_probability"] = meteo_result[
                ][hour]
                data[hour]["data"][city]["precipitation"] = meteo_result[
                    "precipitation"
                ][hour]
                data[hour]["data"][city]["european_aqi"] = air_result["european_aqi"][
                    hour
                data[hour]["data"][city]["us_aqi"] = air_result["us_aqi"][hour]
        go_or_not = (data[7]["super_indice"] or data[8]["super_indice"]) and (
            data[17]["super_indice"] or data[18]["super_indice"]
        score = 0
        _LOGGER.info("Populate Ready To Bike Sensor")
            "score": score,
            "indice": go_or_not,
            "day": date_of_the_day,
            "data": data,
        _LOGGER.info("End of function call_open_meteo")
        return True
    # initialize sensor's variables
    _LOGGER.info("Launch async_call_open_meteo function")
    hass.helpers.discovery.load_platform("sensor", DOMAIN, {}, config)
    hass.services.async_register(
        DOMAIN,
        "call_open_meteo_bike_api",
        call_open_meteo_api,
        # schema=SEARCH_ITEMS_SCHEMA,
        supports_response=SupportsResponse.ONLY,
    return True
async def fetch_weather_data(hass, date_of_the_day, city):
    _LOGGER.info("Call fetch_weather_data " + str(city[0]) + " et " + str(city[1]))
    httpAnswer = await hass.async_add_executor_job(
        urlopen,
        "https://api.open-meteo.com/v1/forecast?latitude=%s&longitude=%s&hourly=temperature_2m,apparent_temperature,precipitation_probability,precipitation,rain,showers,snowfall&timezone=Europe/Berlin&start_date=%s&end_date=%s"
        % (city[0], city[1], date_of_the_day, date_of_the_day),
    result = json.loads(httpAnswer.read())["hourly"]
    if result:
        return result
    else:
        raise Exception("Erreur lors de la requête météorologique")
async def fetch_air_quality_data(hass, date_of_the_day, city):
        urlopen,
        "https://air-quality-api.open-meteo.com/v1/air-quality?latitude=%s&longitude=%s&hourly=alder_pollen,birch_pollen,grass_pollen,mugwort_pollen,olive_pollen,ragweed_pollen,european_aqi,european_aqi_pm2_5,european_aqi_pm10,european_aqi_no2,european_aqi_o3,european_aqi_so2,us_aqi&timezone=Europe/Berlin&start_date=%s&end_date=%s&domains=cams_europe"
    if result:
        return result
    else:
        raise Exception("Erreur lors de la requête air qualité")
File: sensor.py
"""Platform for sensor integration."""
from homeassistant.components.sensor import SensorEntity
from homeassistant.core import HomeAssistant
from homeassistant.helpers.entity_platform import AddEntitiesCallback
from homeassistant.helpers.typing import ConfigType, DiscoveryInfoType
from . import DOMAIN
import logging
def setup_platform(
    config: ConfigType,
    add_entities: AddEntitiesCallback,
    discovery_info: DiscoveryInfoType | None = None,
) -> None:
    """Set up the sensor platform."""
    # We only want this platform to be set up via discovery.
    if discovery_info is None:
        return
    _LOGGER.info("Create Ready To Bike Sensor Platform ")
    _LOGGER.debug(f"Config : {config}  ")
    add_entities([ReadyToBike(config)])
class ReadyToBike(SensorEntity):
    """Representation of a sensor."""
    def __init__(self, data) -> None:
        """Initialize the sensor."""
        self._state = None
        self._attr_extra_state_attributes = {}
    @property
    def name(self) -> str:
        """Return the name of the sensor."""
        return "Ready To Bike Sensor"
    @property
    def state(self):
        """Return the state of the sensor."""
        return self._state
    def update(self) -> None:
        """Fetch new state data for the sensor.
        This is the only method that should fetch new data for Home Assistant.
        _LOGGER.info("Update Ready To Bike Sensor ")
        self._state = self.hass.data[DOMAIN].get("score", 0)
        self._attr_extra_state_attributes["day"] = self.hass.data[DOMAIN]["day"]
        self._attr_extra_state_attributes["indice"] = self.hass.data[DOMAIN]["indice"]
        self._attr_extra_state_attributes["data"] = self.hass.data[DOMAIN]["data"]
