I have an installation which works as one would hope. Z-Wave, MQTT for Tasmota devices, MySensors for sensors and actuators. This is HAOS running in Virtual Box on a linux machine.
It’s an actual refurbished PC I got for under $100 on Amazon (Core i5-4570 3.2GHz 8GB 500GB DVDRW) (Recommend $10 2yr warrantee extension) because RPi’s are selling for a ridiculous price.
Now I’m trying to replicate that system. (export HAOS to a .ova, import on target machine) The Tasmota and MySensors was seamless. The Z-Wave is going to have to be a fresh start. I used the painful process (simplicity studio, tip, you must get account and log in) of resetting the ZST 10 700. I removed the Z-Wave integration, the Z-Wave JS add-on.
I plug in my ZST 10 700 which, to the linux system, is /dev/ttyUSB0. The virtual box sees my Z-Wave stick settings under USB,
When I attempt install the integration with add-on checked, I come to the page that Enter the Z-Wave JS add-on configuration which has the note The add-on will generate security keys if those fields are left empty. and next to USB Device Path nothing
Clicking on [submit] I get the error Not all required fields are filled in.
Remember, the OS, Virtual Box, HAOS are all working on another system. I have tried three settings the USB type in the settings of the Virtual box. I do not have access to the other system.
Any thoughts?
OSD
