Thanks lots for the reply. Sorry I was writing that on the phone from work so probably didn’t come across well.
I can take last night as an example. Before I went to bed I entered ‘HASS’ to start the service from my laptop on terminal. Opened the UI and it appeared with no issue on port 8123. When I look this morning from the same computer it tells me connection refused.
I copied the logs but are two instances of this running at the same time?
PS. Don’t mind the taklampa TV entry in tellstick. Is a dummy one. Thanks again
Config directory: /home/pi/.homeassistant
WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=toggle, domain=homeassistant>
INFO:homeassistant.bootstrap:Home Assistant core initialized
INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
INFO:homeassistant.loader:Loaded http from homeassistant.components.http
INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
INFO:homeassistant.loader:Loaded device_tracker from homeassistant.components.device_tracker
INFO:homeassistant.loader:Loaded zone from homeassistant.components.zone
INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
INFO:homeassistant.loader:Loaded history from homeassistant.components.history
INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
INFO:homeassistant.loader:Loaded api from homeassistant.components.api
INFO:homeassistant.loader:Loaded tellstick from homeassistant.components.tellstick
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=log, domain=logbook>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
INFO:homeassistant.loader:Loaded switch.tellstick from homeassistant.components.switch.tellstick
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=switch>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=switch>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=toggle, domain=switch>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=zone.home, new_state=<state zone.home=zoning; icon=mdi:home, friendly_name=Home, longitude=-6xxxxxxx5, hidden=True, radius=100, latitude=5xxxxxx @ 08:22:55 07-04-2016>, old_state=None>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=zone>
INFO:homeassistant.loader:Loaded device_tracker.owntracks from homeassistant.components.device_tracker.owntracks
INFO:homeassistant.loader:Loaded mqtt from homeassistant.components.mqtt
INFO:homeassistant.loader:Loaded mqtt.server from homeassistant.components.mqtt.server
INFO:hbmqtt.broker:Listener 'ws-1' bind to 0.0.0.0:8080 (max_connecionts=-1)
INFO:hbmqtt.broker:Listener 'default' bind to 0.0.0.0:1883 (max_connecionts=-1)
INFO:hbmqtt.broker:Listener 'default': 1 connections acquired
INFO:hbmqtt.broker:Connection from 127.0.0.1:47843 on listener 'default'
WARNING:hbmqtt.broker:Delete session : session paho/35AA0xxxxx77A762532 doesn't exist
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=publish, domain=mqtt>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mqtt>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_devices, new_state=<state group.all_devices=unknown; entity_id=(), hidden=True, order=0, auto=True, friendly_name=all devices @ 08:23:02 07-04-2016>, old_state=None>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=see, domain=device_tracker>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=device_tracker>
/home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning
warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning')
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=process, domain=conversation>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sun.sun, new_state=<state sun.sun=above_horizon; next_setting=19:11:59 07-04-2016, friendly_name=Sun, elevation=xxxx01, next_rising=05:39:57 08-04-2016 @ 08:23:04 07-04-2016>, old_state=None>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
INFO:homeassistant.components.tellstick:discovered 4 new switch devices
INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=devices=[1, 3, 4, 5], config=1, service=tellstick.switches>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=switch.vardagsrum_taklampa_tv, new_state=<state switch.vardagsrum_taklampa_tv=off; friendly_name=Vardagsrum taklampa TV, assumed_state=True @ 08:23:04 07-04-2016>, old_state=None>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=tellstick>
INFO:homeassistant.core:Starting Home Assistant (16 threads)
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=switch.kitchen_plug_tv, new_state=<state switch.kitchen_plug_tv=on; friendly_name=Kitchen Plug TV, assumed_state=True @ 08:23:04 07-04-2016>, old_state=None>
INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
INFO:homeassistant.core:Timer:starting
INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=restart, domain=homeassistant>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=switch.kitchen_plug_apple_charger, new_state=<state switch.kitchen_plug_apple_charger=off; friendly_name=Kitchen Plug Apple Charger, assumed_state=True @ 08:23:04 07-04-2016>, old_state=None>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=switch.kitchen_plug_microwave, new_state=<state switch.kitchen_plug_microwave=on; friendly_name=Kitchen Plug Microwave, assumed_state=True @ 08:23:04 07-04-2016>, old_state=None>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_switches, new_state=<state group.all_switches=unknown; entity_id=[], hidden=True, order=1, auto=True, friendly_name=all switches @ 08:23:04 07-04-2016>, old_state=None>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_switches, new_state=None, old_state=<state group.all_switches=unknown; entity_id=[], hidden=True, order=1, auto=True, friendly_name=all switches @ 08:23:04 07-04-2016>>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_switches, new_state=<state group.all_switches=on; order=1, auto=True, friendly_name=all switches, entity_id=('switch.kitchen_plug_microwave', 'switch.vardagsrum_taklampa_tv', 'switch.kitchen_plug_apple_charger', 'switch.kitchen_plug_tv'), hidden=True, assumed_state=True @ 08:23:04 07-04-2016>, old_state=None>
WARNING:homeassistant.components.recorder:Found unfinished sessions
