Need to tomorrow the pump on/off if it has been in the inverse state for 2+ hours
I have this, and it works perfectly, unless the heat is trying to catch up, or automations get reloaded or… Anything that means the pump can’t be toggled at EXACTLY 7200 seconds. Then the pump just stays in the previous state until some other outside force acts.
I want the system to trigger a change if the pump state is on/off for any reason beyond 2 hours when the other condition(s) stop.
alias: Hot Tub Pump and Heater On
description: Turns on the Pump and Heater after the pump has been off for 2 hours.
  - platform: device
    type: turned_off
    device_id: b26321a9a3bce7452776ab81768263eb
    entity_id: 4ebdeff4feaab235eccf9f6d101b1e18
    domain: switch
    for:
      hours: 2
      minutes: 0
      seconds: 0
    enabled: true
  - platform: device
    type: turned_on
    entity_id: a6a4557d968d89c246b4eae570a28b37
    domain: switch
  - type: temperature
    platform: device
    entity_id: 9b88da1278a356e51fbf450ca639b59d
    domain: sensor
    below: 93
    enabled: false
condition: []
  - type: turn_on
    domain: switch
  - type: turn_on
    entity_id: 7225b6999f5f6e2269cc1da8ea62710a
    domain: switch
mode: single
