Thank you. The only things I would suggest are (1) try another gpio, some don’t work well (although not usually a problem with esp32) or (2) maybe the colours don’t match the esphome docs. How to diagnose the latter without a signal analyser I have no idea.
I assume you have tried to spin the vanes around to generate some data?
I can try a different GPIO… but I doubt. I saw for some pure arduino implementation, some used a 10K pullup resistance. I tried without luck.
Colors seems to match but … yes without a signal analyser, it will be hard.
For sure I tried by both spinning and rotating nothing is here …
The difference from the Tx20 to the Tx23 seems to be that the green cable does not matter anymore and the wind sensor is just sending a datagram every 2 seconds -
I ailso tried the ESPhome implementation on a different ESP & GPIO… and nothing worked…
So clearly the ESPhome TX20 implementation is buggy for the TX23. I opened an issue
