I just added a 3-button Zigbee scene switch, Tuya TS0043, into Zigbee2MQTT. I had zero issues adding it to Z2M or HA. I copied a Blueprint that I found on here, but it’s not working. I see log entries for the BP Automation when I press a button, but it doesn’t perform any of the actions I’ve defined, including sending notifications. The blueprint and a section of logs is below.
blueprint:
name: Zigbee2MQTT - Loratap SS600ZB / Tuya TS0043 Zigbee Wireless Switch
description: Automate your Loratap SS600ZB / Tuya TS0043 Zigbee Wireless Switch via Zigbee2MQTT.
domain: automation
input:
switch:
name: Loratap SS600ZB / Tuya TS0043 Zigbee Wireless Switch
description: Loratap SS600ZB / Tuya TS0043 Zigbee Wireless Switch to use
selector:
entity:
integration: mqtt
domain: sensor
button_one_short_press:
name: Single Press - Button 1
description: Action to run on button 1 - single press
default: []
selector:
action: {}
button_one_double_press:
name: Double Press - Button 1
description: Action to run on button 1 - double press
default: []
selector:
action: {}
button_one_long_press:
name: Long Press - Button 1
description: Action to run on button 1 - long press
default: []
selector:
action: {}
button_two_short_press:
name: Single Press - Button 2
description: Action to run on button 2 - single press
default: []
selector:
action: {}
button_two_double_press:
name: Double Press - Button 2
description: Action to run on button 2 - double press
default: []
selector:
action: {}
button_two_long_press:
name: Long Press - Button 2
description: Action to run on button 2 - long press
default: []
selector:
action: {}
button_three_short_press:
name: Single Press - Button 3
description: Action to run on button 3 - single press
default: []
selector:
action: {}
button_three_double_press:
name: Double Press - Button 3
description: Action to run on button 3 - double press
default: []
selector:
action: {}
button_three_long_press:
name: Long Press - Button 3
description: Action to run on button 3 - long press
default: []
selector:
action: {}
source_url: https://github.com/AramidX/ha-blueprint/blob/8e259f8e40ab1218f06ea1ce1d1444f67b4cd62f/blueprints/tuya/loratap_ss600zb_wireless_switch_z2m.yaml
mode: restart
max_exceeded: silent
- platform: state
entity_id: !input "switch"
- variables:
command: '{{ trigger.to_state.state }}'
- choose:
- conditions:
- '{{ command == ''1_single'' }}'
sequence: !input 'button_one_short_press'
- conditions:
- '{{ command == ''2_single'' }}'
sequence: !input 'button_two_short_press'
- conditions:
- '{{ command == ''3_single'' }}'
sequence: !input 'button_three_short_press'
- conditions:
- '{{ command == ''1_double'' }}'
sequence: !input 'button_one_double_press'
- conditions:
- '{{ command == ''2_double'' }}'
sequence: !input 'button_two_double_press'
- conditions:
- '{{ command == ''3_double'' }}'
sequence: !input 'button_three_double_press'
- conditions:
- '{{ command == ''1_hold'' }}'
sequence: !input 'button_one_long_press'
- conditions:
- '{{ command == ''2_hold'' }}'
sequence: !input 'button_two_long_press'
- conditions:
- '{{ command == ''3_hold'' }}'
sequence: !input 'button_three_long_press'
Kitchen 3 button test triggered
7:29:34 PM - 1 minute ago
Kitchen 3 button test triggered by state of Kitchen 3 button test turned on
7:29:02 PM - 1 minute ago
Kitchen 3 button test triggered by state of kitchen_light_sw3 Action
kitchen_light_sw3 Action changed to 1_double
7:29:00 PM - 1 minute ago
kitchen_light_sw3 Action changed to 1_single
7:28:47 PM - 1 minute ago
