Neerslag Card (rain forecast) (Buienalarm and/or Buienradar)
Same issue here (iPad Air running IOS 12.5.6). Did you manage to solve it?
Today i updated hacs and mushroom cards and after rebooting ha i have the same error Custom element doesn’t exist: neerslag card.
I already redownloaded the integration and completely removed it but it doesn’t solve it.
Someone a solution?
@aex351 I am getting not in coverage or Not found: location must be inside the Netherlands or Belgium when installing these. I’m in the UK, but both sites support the UK.
What’s going on ?
Did you ever get this working? I’m in the UK and i get the messages ‘no coverage’ as well. Would love to have this added.
I had the same issue but than with my Android phones. PC working fine, Android same issue.
Also I managed to fix it:
It turned out I only installed the “Neerslag App” on the “integration” tab in HACS. After also installing the “Neerslag Card” on the “frontend” tab it started also working on Android.
Upgraded to a more recent iPad running the latest iOS and now it works well.
Apparently the website supports locations outside the Netherlands and Belgium, however the API doesn’t.
I’d love to see support for more locations. Maybe the way has to be to add other data providers to the card or even the app.
Is there a way to get the card to show the chart of the current days weather?
Similar to the Buienalarm app view where you see the hourly predicted temp and conditions
Hi any update on this?
We are 2023, u said in sep 21 u would add more sensors…
Still planning to?
@X1pheR
Still planning to add these additional sensors? Otherwise I will keep using my Node-Red integration.
Additional sensors will be done in the neerslag-app, not in the neerslag-card.
Next to that, I pushed an update that requires a manual update of custom sensors that use Buienalarm (for those that don’t use the neerslag-app). This will improve the Buienalarm data. In case of any other issues, make sure to delete the browser/app cache.
