018-08-23 16:54:52 ERROR (SyncWorker_18) [sleekxmpp.xmlstream.resolver] All nameservers failed to answer the query wa2-mz36-qrmzh6.bosch.de. IN AAAA: Server 172.30.32.2 UDP port 53 answered DNS message is malformed.
File “/config/deps/lib/python3.6/site-packages/sleekxmpp/xmlstream/resolver.py”, line 242, in get_AAAA
recs = resolver.query(host, dns.rdatatype.AAAA)
File “/usr/local/lib/python3.6/site-packages/dns/resolver.py”, line 947, in query
raise NoNameservers(request=request, errors=errors)
dns.resolver.NoNameservers: All nameservers failed to answer the query wa2-mz36-qrmzh6.bosch.de. IN AAAA: Server 172.30.32.2 UDP port 53 answered DNS message is malformed.
2018-08-23 16:54:52 ERROR (read_thread) [sleekxmpp.xmlstream.xmlstream] Certificate has expired.
2018-08-23 16:54:52 WARNING (read_thread) [sleekxmpp.xmlstream.xmlstream] Failed to send b"<stream:stream to=‘wa2-mz36-qrmzh6.bosch.de’ xmlns:stream=‘http://etherx.jabber.org/streams’ xmlns=‘jabber:client’ xml:lang=‘en’ version=‘1.0’>"
2018-08-23 16:54:52 ERROR (read_thread) [sleekxmpp.xmlstream.xmlstream] Socket Error #9: Bad file descriptor
2018-08-23 16:54:58 ERROR (read_thread) [sleekxmpp.xmlstream.resolver] All nameservers failed to answer the query wa2-mz36-qrmzh6.bosch.de. IN AAAA: Server 172.30.32.2 UDP port 53 answered DNS message is malformed.
2018-08-23 16:54:59 ERROR (read_thread) [sleekxmpp.xmlstream.xmlstream] Certificate has expired.
2018-08-23 16:54:59 WARNING (read_thread) [sleekxmpp.xmlstream.xmlstream] Failed to send b"<stream:stream to=‘wa2-mz36-qrmzh6.bosch.de’ xmlns:stream=‘http://etherx.jabber.org/streams’ xmlns=‘jabber:client’ xml:lang=‘en’ version=‘1.0’>"
2018-08-23 16:54:59 ERROR (read_thread) [sleekxmpp.xmlstream.xmlstream] Socket Error #9: Bad file descriptor
2018-08-23 16:54:59 WARNING (MainThread) [homeassistant.components.climate] Setup of platform nefit is taking over 10 seconds.
2018-08-23 16:55:05 ERROR (read_thread) [sleekxmpp.xmlstream.resolver] All nameservers failed to answer the query wa2-mz36-qrmzh6.bosch.de. IN AAAA: Server 172.30.32.2 UDP port 53 answered DNS message is malformed.
2018-08-23 16:55:05 ERROR (MainThread) [homeassistant.components.sensor] scrape: Error on device update!
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 248, in _async_add_entity
await entity.async_device_update(warning=False)
File “/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py”, line 322, in async_device_update
yield from self.hass.async_add_job(self.update)
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/sensor/scrape.py”, line 120, in update
value = raw_data.select(self._select)[0].text
IndexError: list index out of range
2018-08-23 16:55:06 ERROR (read_thread) [sleekxmpp.xmlstream.xmlstream] Certificate has expired.
2018-08-23 16:55:06 WARNING (read_thread) [sleekxmpp.xmlstream.xmlstream] Failed to send b"<stream:stream to=‘wa2-mz36-qrmzh6.bosch.de’ xmlns:stream=‘http://etherx.jabber.org/streams’ xmlns=‘jabber:client’ xml:lang=‘en’ version=‘1.0’>"
2018-08-23 16:55:06 ERROR (read_thread) [sleekxmpp.xmlstream.xmlstream] Socket Error #9: Bad file descriptor
first of all thanks for the great Nefit component!
Recently the Dutch language was released for Google Assistant, so I bought a couple of Google Homes. Everything in HASS is working as expected except for this custom climate component.
It is visible in the Google Home app and it will show the current measured temperature but setting a temperature is not possible. Not by voice or in the Google app. In the app it just keeps saying ‘loading’.
Does this component work for someone else from within the Google Assistant/Home app or by voice? That would mean I have something setup wrong. Or is this a shortcoming/bug in the ha-nefit component?
I tried using IFTTT the set the temperature directly on the Nefit with Google Assistant, unfortunatly IFTTT doesn’t support the Dutch assistant language yet…
Yes! finally working under HASSIO.
I first installed the dependencies in a docker home assistant image.
Then I copied the folder deps from the docker image to the hassio config folder!
It is working. HASSIO is reading the temperatures and I can manage it!
Sat Oct 27 2018 10:04:56 GMT+0200 (Midden-Europese zomertijd)
DNS: dnspython not found. Can not use SRV lookup.
<OctetString schema object at 0x6ead75b0 tagSet <TagSet object at 0x72ee3550 tags 0:0:4> encoding iso-8859-1>
File “/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/xmlstream.py”, line 1492, in _process
if not self.__read_xml():
File “/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/xmlstream.py”, line 1564, in __read_xml
self.__spawn_event(xml)
File “/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/xmlstream.py”, line 1632, in __spawn_event
handler.prerun(stanza_copy)
File “/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/handler/callback.py”, line 64, in prerun
self.run(payload, True)
File “/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/handler/callback.py”, line 76, in run
self._pointer(payload)
File “/usr/local/lib/python3.6/site-packages/sleekxmpp/features/feature_starttls/starttls.py”, line 64, in _handle_starttls_proceed
if self.xmpp.start_tls():
File “/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/xmlstream.py”, line 889, in start_tls
cert.verify(self._expected_server_name, self._der_cert)
File “/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/cert.py”, line 134, in verify
cert_names = extract_names(raw_cert)
File “/usr/local/lib/python3.6/site-packages/sleekxmpp/xmlstream/cert.py”, line 73, in extract_names
asn1Spec=OctetString())[0]
File “/usr/local/lib/python3.6/site-packages/pyasn1/codec/ber/decoder.py”, line 1318, in call
‘%s not in asn1Spec: %r’ % (tagSet, asn1Spec)
pyasn1.error.PyAsn1Error: <TagSet object at 0x6f86f350 tags 0:32:16> not in asn1Spec: <OctetString schema object at 0x6ead75b0 tagSet <TagSet object at 0x72ee3550 tags 0:0:4> encoding iso-8859-1>
“I figured out a littlebit more, it seems they updated the sleekxmpp component from 1.3.2 to 1.3.3, and this breaks the Nefit (and apparently Netflix) plugins.
Still not sure what in 1.3.3 changed to break this.”
Thanks! This change makes the Easy work with the Google Home app, I haven’t tried it with voice commands yet though. Although I expect no issues with that.
However this does change the state reported in Home Assistant aswell though. I tried editing the trait.py in the google_assistant component. To keep the idle state in Hass but report ‘cool’ state to GHome.
But since I’m running HASSio the change in the Docker container isn’t saved after a reboot and thus never becomes active. Then I tried adding google_assistant as a custom component to overwrite the default, but even without any changes the custom component fails to load with a error: importError: cannot import name ‘CLOUD_NEVER_EXPOSED_ENTITIES’
Any tips? Otherwise I will just keep it the way you suggested. It is no big deal, but it does trigger my OCD.
Does anyone know if there is some kind of tutorial or something to get this working on Hass.io?
I have read this topic, but i’m to new at Home Assistant to get this stuff working…
Light bulb’s and buttons etc is a piece of cake in HA but this thing is a tough nut to crack
I dont see any response for getting is to work in hassio. I’m using this one also, and like to get my nefit easy in hassio. every google search has turned me down and still not getting is to work. unable to install pyaes in this os. please help.
