What I really would like is an automation for my Nefit thermostat / CV.
1.When the door is open for 2 minutes the CV has to be turn off or lower the heat.
2.The second automation is when the door is closed again the CV has to be going to the default setting. Here starts my problem. You have a ‘program’ what the thermostat was following, but there is also a ‘manually’ setting (you can manually set the temperature higher of lower). So what I want is when the door is closed the thermostat is actually going to the setting of the moment before te door opened.
I made a automation and the first part is working nice. When my door is opened the Nefit will go to 15 degrees (first I wanted it to turn off but I couldn’t found this)
But the second part of the automation isn’t working and I would appreciated your help.
Thanks is advange
Bastiaan1977
- id: '1616413746874'
alias: CV uit als schuifpui open is
description: ''
- type: opened
platform: device
device_id: d8faa9f161b3b33e3ebb03627b19d935
entity_id: binary_sensor.schuifpui_sensor20_23816922_ias_zone
domain: binary_sensor
for:
hours: 0
minutes: 2
seconds: 0
milliseconds: 0
condition: []
- service: climate.set_temperature
entity_id: climate.nefit
temperature: 15
mode: single
- id: '1616414006504'
alias: CV aan als schuifpui dicht is
description: ''
- type: not_opened
platform: device
for:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
condition: []
- device_id: c83324ff0b3f42dbf82066026520819d
domain: climate
type: set_hvac_mode
hvac_mode: heat
mode: single
Thanks for your comment. I have tried it but I can’t get it working.
Do I have to change the two binary sensors (0x00158…_occupancy and _contact) to my sensors?
- platform: state
entity_id:
- binary_sensor.schuifpui_sensor20_23816922_ias_zone
to: 'on'
In the 1st automation. In the second to: ‘off’
I dont think thats the problem anyway.
Take a look at Developer Tools → Template to check whats failing.
What kind of contact sensor do you have? In the ones i have (the xiaomi zigbee ones), they stay on for 2 minutes, which its a problem for some automations.
The problem is in your HVAC Mode in your last action, nefit does not do anything with this action.
You have to work with a preset_mode:Clock to put your thermostat back in normal operation.
Example:
service: climate.set_preset_mode
preset_mode: Clock
Good Luck
@swalue
Thanks for your reply, I have tried this but it doesn’t work. Although, the HVAC Mode is Clock, but is there somehow a way that the HVAC mode is going to the last setting? Manual for example.
Here is what I want to do:
-when my door is open the Nefit has to be off (or like I have now the temperature is going to 15 degrees) Maybe I have to change this ??
-then when my door is closed again my Nefit has to go to:
1. the clock setting or
2. the manual temperature that was set before the door was opened.
I hope that you can help me with this. Here are my current setting2 is yaml:
description: ''
- type: opened
platform: device
for:
hours: 0
minutes: 2
seconds: 0
milliseconds: 0
condition: []
temperature: 15
mode: single
description: ''
- type: not_opened
platform: device
for:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
condition: []
- service: climate.set_preset_mode
preset_mode: Clock
mode: single
Works like a charm, was playing around with the hvac modes, but seems they are not really supported for the bosch-nefit easy, only has hvac_modes: heat
Thanks again, when i have the time i’ll try to create a blueprint out of it
