For no apparent reason, since november 3rd, I’m starting to see negative statistics in the HA Energy dashboard and other values that make no sense. From the sensor data I can see that the values are increasing like normally. Also I see some water usage in the middle of the night while this really has not happened. Anyone got a clue what is going on here and how can I fix it? I’m running HAOS in a proxmox VM with a Mariadb database as addon.
I have the same problem.
The water part of the dashboard is not oke…
Even when you add a sensor without any water usage you get strange values…
