Negative Energy?
Any idea why my dishwasher energy usage is showing negative numbers. All of these in the picture are using Shelly Plugs to gather the data. The dishwasher is the only one showing like that.
Are the values from the dishwasher sensor current usage (going up and down), total usage (always rising value) or e.g. per day (increasing and resetting at the end of the day, or when HA is restated or something like that?). Afaik the enery dashboard expects a total-increasing, and will substract the value at midnight from the current value to get todays usage. So if your dishwasher is reporting the current useage 0 now, but reported 17 at the start of the day because it was running then, you’ll get figures like this. So probably you’re using the wrong type sensor.
any luck solving this?
mine was working fine, but after moving from VM to RPi4 i have the same problem :slight_smile:
