PS: those are entities that have been modified in the “Customize” section to add the measurement state, last_reset and changed the power state to energy
For HS110 when you add devices to individual devices, add total Consumption not Daily which reset every day and will give you negative value; watch there are 2 consumptiun for HS110, you need to add total.
Had a similar issue with a ZooZ ZEN25, rediscovering it addressed my problem. Have you tried a rediscovery? I know the chance of that fixing it is slim but it is quick to do if you have not already done it.
I took the suggestion from Alex and it seemed that the AC’s had a yearly overview as well.
So modified that with the necessary states and that seemed to work.
But thanks for the suggestion!
Hi, I have a Tuya smart plug with I run with the Tuya local integration. I want to be able to add it as Individual device how do you change / modify the customize so it will show up in the device drop downlist. ?
I also only have.
switch.office_power.attributes.current which is in ‘mA’ and
switch.office_power.attributes.current_consumption which is in W
as far as I can read here I would have to create some total power consumption entity measured in kWh. Do anyone have an idea what I would need to create in configuration.yaml for it to work for Tuya or point me in some general guide.
This is what I have currently to create 2 entities for my existing cards.
