I have a strange problem with one of mine Neo CoolCam Door/Window Sensors.
First: I have it placed so Neo sensor have a powered node that is its neighbour.
Second: It worked perfectly fine for two years.
Now the problem:
When I open the door, nothing happens, not even the indicator flashes.
When I close the door, nothing happens, not even the indicator flashes.
Then I open the door again, it works just fine. Sending to HA and I can see the change.
I close the door, it works just fine. Sending to HA and I can see the change.
The I open the door for the third time, nothing happens, not even the indicator flashes.
II close the door, nothing happens, not even the indicator flashes.
This repeats so every other time it dont react.
Anyone else this happend for?
I’ve just bought 3 CoolCam door sensors. And they detect an open/close every two times.
So they detect the first open-close, but they will not detect the 2nd open-close, and they will detect the 3rd open close, but not the 4th, and yes the 5th…and so…and so
However, if you use for gliding doors or windows it works well (you approach in longitudinal axis of the main body)
