Neo Coolcam Motion Sensor support?
I’m trying to find out if anyone has gotten the Neo Coolcam Motion Sensor to work with Home Assistant and OpenZWave?
I have connected 2 up, and my OZW_Log.txt is full of these entries:
2016-12-29 00:45:56.999 Detail,
2016-12-29 00:45:56.999 Info, Node007, ApplicationCommandHandler - Unhandled Command Class 0x71
2016-12-29 00:45:57.022 Detail, Node007,   Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x07, 0x04, 0x30, 0x03, 0xff, 0x0c, 0x32
2016-12-29 00:45:57.022 Info, Node007, ApplicationCommandHandler - Unhandled Command Class 0x30
2016-12-29 00:46:15.795 Detail, Node007,   Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x07, 0x09, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x08, 0x00, 0x7e
2016-12-29 00:46:15.795 Info, Node007, ApplicationCommandHandler - Unhandled Command Class 0x71
2016-12-29 00:46:15.817 Detail, Node007,   Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x07, 0x04, 0x30, 0x03, 0xff, 0x0c, 0x32
2016-12-29 00:46:15.817 Info, Node007, ApplicationCommandHandler - Unhandled Command Class 0x30
Any ideas?
Hi
Yes I have gotten it to work. Do you still have a problem? I have had Z-wave issues as well and it has always been problems adding devices. Make sure you are able to add the device properly in OpenZwave. Remember to reset the motion sensor before you start adding it to your Hub.
Br,
Jan Morten
