NEO coolcam pir not showing up motion (zwavejs)
Hi, I have included my pir sensors with zwavejs. 1 pir is showing the binary motion sensor and the other pir is not showing the binary motion sensor. The pirs are exactly the same as you can see on the screenshot. Anyone has a solution for this ?
Did you tryid to reload / restart zwavejs integration?
I performed a complete fresh rebuild of my Home assistant, which is the VirtualBox VM, but all of my Neo Coolcam motion sensors are failing to show. They all say the same as yours - asleep
Did you find a solution?
OK, so my fix was to remove the battery on the devices, wait 10s and fit back. This caused a re-initialise I guess and all info is now showing up correctly.
Hope this helps someone else.
