I have been using Neo coolcam plugs without any issues for a while. Now when I ad one each one gives the notification “This device is buggy and sends large negative Meter Reports from time to time.”
How can I solve this (I am a newby)
There is known issue with them. They do send negative energy values from time to time.
You can read this to know more.
There is a workaround. Creating a sensor template and use that as your reading sensor.
Example:
- sensor:
- name: "Correct energy sensor"
unit_of_measurement: kWh
device_class: energy
state_class: total_increasing
state: >-
{% set value = states('sensor.neocoolcam_electric_consumption_kwh') | float(0) %}
{% set const = 21474836.47 %}
{% if value < 0 %}{{ (value + const) | round(2) }}
{% else %}{{ value }}
{% endif %}
But read the stuff first, so you understand why and how…
Thank you for your reply! I will try this.
If you are lucky and your neo coolcam plug has a esp inside you actually can fix this installing a custom (proper) firmware like esphome.
When you plug is a black box (z-technology) on the other hand you need to work with the work’a’round to don’t end up with complete garbage measurements.
Thanks, google tells this is only done with the Wifi plugs. I am using Zwave.
Then you are stuck with the what the seller shipped to you (hardware&software) and are dependent on the goodwill of the manufacturer to get any updates.
Typically manufacturers prefer not to fix bugs in old products but instead release new ones which they can sell again
The right to repair is not present in products which don’t allow you to run your own *ware
then I just have to deal with it. Use fibaro were I want to know the electric consumption, the neo coolcam were i want only use the switch.
Thanks!
You can still use the Neo for consumption with the above mentioned workaround.
I am trying to add this to HA but I am doing something wrong. I copy and pasted it in the configeration.yalm but this gives errors. Were do I need to paste it? Sorry for maybe a stupid question but I am new to this and ready to learn :-).
Example copy from my configuration.yaml:
# Templates
template:
- sensor:
- name: "NeoPlugNAS OK Energy"
state: >-
{% set value = states('sensor.neoplugnas_electric_consumption_kwh') | float(0) %}
{% endif %}
Thanks! I was missing :
Templates
template:
For my learning, how does HA now knows which plug is a Neo coolcam? Or do I need to make a new “sensor” for each plug and replace “sensor.neoplugnas_electric_consumption_kwh” with the name of that plug?
This is, how it looks with 4 of them:
# Templates
template:
- sensor:
state: >-
{% endif %}
- sensor:
- name: "NeoPlugJacuzzi OK Energy"
state: >-
{% set value = states('sensor.neoplugjacuzzi_electric_consumption_kwh') | float(0) %}
{% endif %}
- sensor:
- name: "NeoPlugVaatwasser OK Energy"
state: >-
{% set value = states('sensor.neoplugvaatwasser_electric_consumption_kwh') | float(0) %}
{% endif %}
- sensor:
- name: "NeoPlugHA OK Energy"
state: >-
{% set value = states('sensor.neoplugha_electric_consumption_kwh') | float(0) %}
{% endif %}
yes, you make a new template sensor for each Neo.
Thank you!!! , mijn dank is groot. Ik ga hier mee aan de slag!!
Is it also possible to make this work to set high number to 0? I have daily a lot of peaks that I manualy set to 0. Could a sensor make a change if the kWh is higher than 5 than set to 0?
This would keep the energy dashbord clean from the start.
I would like to hear from someone, how to enhance this sensor to cut the peaks off. All in one, would be perfect.
But I actually do not know any about writing templates, I just em capable of finding info and use it
So for this, we will need help from some higher experienced mates.
Groetjes uit Amsterdam
