Hi Community
Just bought a Neo CoolCam Power Plug (z wave). Did the normal ‘Add to network’ and the device was picked up. Did a reboot of my Pi and it seems to work.
I can read power, voltage,… and I can turn it on and off from within Home Assistant.
So, almost a success
But…
All the entities for the power plug are registered as ‘unknown type 200’ - like: “sensor.neo_coolcam_unknown_type_0200_id_1027_power”
and with in ‘z-wave node management’ it is listed as:
“Neo CoolCam Unknown: type=0200, id=1027 (Node:6 Complete)”
I can set a ‘Name override’, but have to do that for each entity…, does not seem as the right way to do this, and can’t figure out if this ‘unknown type’ has to be solved first.
How should I proceed ?
These are few of the values:
node id
6
node name
manufacturer name
Neo CoolCam
product name
query stage
Complete
is awake
true
is ready
true
is failed
false
is info received
true
max baud rate
40000
is zwave plus
true
capabilities
beaming, listening, routing, zwave_plus
neighbors
1
sentCnt
14
sentFailed
0
retries
0
receivedCnt
54
receivedDups
0
receivedUnsolicited
44
sentTS
2019-03-01 21:31:48:240
receivedTS
2019-03-01 22:25:44:395
lastRequestRTT
24
averageRequestRTT
23
lastResponseRTT
41
averageResponseRTT
59
Regarnds Jørn
