Hi
I am using Neo Coolcam Powerplug, with Aeotec Zwave Stick Gen 5. I can poweron and poweroff the switch just fine. I am trying to turn of the led since this plug in inside the bedroom.
According to the manual of the power plug it should be done using the following:
- Led Display Enable
This parameter defines the LED indication Function ON/OFF. This parameter can be configured with 0 or 1, where 0 means disable LED indication Function and will always be turn‐off, and 1 means enable LED Function.
Function: LED Enable/Disable
Parameter Number: 5.
Parameter Size: 1 Byte
Available Settings: 0, 1.
Default Setting: 1.
So I used the "zwave.print_config_parameter"service with the following data:
“node_id”: 3,
“parameter”: 5,
“value”: 0
In the OZW log I see:
Notification: ValueChanged
However the led stays on. Anybody ran into this by any chance?
Thanks,
Ad
you can disable the LED via the Z-Wave controlpanel:
Home Assistant Web Interface -> Settings -> Z-Wave -> Node management -> Select your node
Node config options ->
Tested and worked for me for two of the Neo Coolcam (EU) plugs.
Thank you for this! This did the trick.
To gain quick access to the LED configuration of a Neo Coolcam PowerPlug you can define an input_boolean and use that in an automation calling the zwave.set_config_parameter service.
In configuration.yaml:
input_boolean:
switch_bedroom_config_led:
name: LED indicator for bedroom switch
icon: mdi:lightbulb-on-outline
In automations.yaml:
- id: disable_switch_bedroom_led
alias: Disable LED indicator
entity_id: input_boolean.switch_bedroom_config_led
platform: state
to: 'off'
service: zwave.set_config_parameter
data_template: {
"node_id": 2,
"parameter": 5,
"value": "Disable"
- id: enable_switch_bedroom_led
alias: Enable LED indicator
platform: state
to: 'on'
data_template: {
"node_id": 2,
"parameter": 5,
"value": "Enable"
I’m using this for two Neo Coolcam PowerPlugs and it works like a charm.
