How did you manage to add this device in the first place? Did u use “add node” or “add node secure”
Actually i tried with both n nothing happens. It appears that the device never sends anything.
Zwave log is like below. Anyone faced the same issue?
Note: In order to force inclusion mode, the manual says to “touch the button 3 times continuously n quickly n then the light will flash yellow+green for 5 times”. Is this anywhere close to what you did when completing the pairing?
The only way i can actually trigger this device to flash its light is by quickly pressing the button three times n then the light flashes green around 16 times - nowhere near to what the manual says.
2020-10-02 13:36:44.851 Detail, Notification: ControllerCommand - Completed
2020-10-02 13:36:46.775 Detail, Queuing (Controller) Add Device
2020-10-02 13:36:46.775 Info, Add Device
2020-10-02 13:36:46.775 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0d, 0x7c
2020-10-02 13:36:46.775 Detail, Notification: ControllerCommand - Starting
2020-10-02 13:36:46.776 Detail,
2020-10-02 13:36:46.776 Info, contrlr, Sending (Command) message (Callback ID=0x0d, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0d, 0x7c
2020-10-02 13:36:46.781 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0d, 0x01, 0x00, 0x00, 0xbe
2020-10-02 13:36:46.781 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-10-02 13:36:46.781 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2020-10-02 13:36:46.781 Detail, Node001, Expected callbackId was received
2020-10-02 13:36:46.781 Detail, Node001, Expected reply was received
2020-10-02 13:36:46.781 Detail, Node001, Message transaction complete
2020-10-02 13:36:46.781 Detail, contrlr, Removing current message
2020-10-02 13:36:46.781 Detail, Notification: ControllerCommand - Waiting
2020-10-02 13:36:46.787 Info, WriteNextMsg Controller nothing to do
