Neon Lovelace UI & Theme for tablets
My new Weather-Dashboard with this great Template.
This is created with some mini-graph-card and apexcharts-card.
When someone is interested in the yaml-code, please let me know.
I meant not using Smhi as the weather. But your example using openweathermap may work! Iā€™ll test it out and report backā€¦thank you!
I cant figure it out either. Did you solve it?
No, unfortunately not.
It seems there is a issue in newer Versions of lovelace-card-mod.
After downgrade to Version 3.0.12 there is no more issue.
ā†’ CSS doesn't seem to work when casting Lovelace page to my Google Hub Ā· Issue #129 Ā· thomasloven/lovelace-card-mod Ā· GitHub
Maybe you get it managed the same way.
Hey @kleinerhobbit,
that looks fantastic. I would be very much interested in the code!
Flo
Nice card. im interested of the yaml-code
Br
Martin
Hey!
I would like to know how to write in configuration.yaml.
Example
front end: xxx /config/theme/neon.yaml
Stort tack! / thanks!
Johnny Samuelsson
Are there any special integrations youā€™ve used for this as Iā€™ve tried your code and changed the entities and I just have errors ā€˜elements requiredā€™ - nothing I do seems to work. Also, the /local/box.png what did you use for this?
Iā€™ve since lost or deleted the yaml for this one but as I recall it was only custom components like card-mod, hui-element, swipe-card, things like that. I think the pastebin I posted above lists them if itā€™s still up.
As for the box.png, itā€™s just a blank / transparent png file in the dimensions of the ha-card of the media card I had made. I think itā€™s supposed to work with just a 1x1px image but I recall having to adjust the size of the image itself.
Hi @danieljarhult
I love your dashboard ! Have you updated it since 2021 ?
Finally I found blur solution:
      - type: custom:button-card
        view_layout:
          grid-area: statuscard
        tap_action:
          action: fire-dom-event
          browser_mod:
              style: |
#this parameters to change pop-up width
                --popup-min-width: 800px;
                --popup-border-radius: 28px;
              card_mod:
                style:
#and this code to blur background
                  ha-dialog$: |
                        div.mdc-dialog__scrim {
                          backdrop-filter: blur(4px) !important;
                          -webkit-backdrop-filter: blur(10px) !important;
                          background-color: rgba(0,0,0,0.1) !important;
And at the end blur background look like this:
Hi guys can someone please help me. Iā€™m currently trying to create a nice design, but I canā€™t get the calendar to appear as it does in the picture.
my card:
grafik
example:
grafik
