Hello all,
I am not much experienced with neither HA nor ESPHome. I am running the latest ESP Home 1.14.3. This is my second ESP board. I connected a test strip of 8 LEDs. The code used is:
light:
- platform: neopixelbus
variant: SK6812
method: ESP8266_UART1
type: GRBW
pin: D4
num_leds: 8
restore_mode: RESTORE_DEFAULT_OFF
Everything works fine from the user interface. There are three sliders for the intensity of each color, a brightness slider for the brightness of the RGB part and a separate slider for the intensity of white. When I programmatic try to power it up with this code:
on_sunset:
- elevation: 2°
then:
- logger.log: "Elevation 2 triggered"
- light.turn_on:
brightness: 20%
white: 0%
red: 20%
green: 20%
blue: 20%
transition_length: 10s
everything works fine, and I get what I have put in the code, but if I give any percentage to white, white is started at 100%. My intention is to use white at 20% as a night light. I have tried these options:
brightness: 20%
white: 20%
red: 0%
green: 0%
blue: 0%
brightness: 0%
white: 20%
red: 0%
green: 0%
blue: 0%
With both I get 100% white, when the event triggers.
The fallback option is to use some RGB white, but the intention was to use white as a night light and the colors for other needs and mood lights. Any help, or idea would be apreciated.
