I have a Ness Alarm panel which I have integrated with HA but I cannot get my Aux Output integrated. My zones and panel work perfectly and I have access to the entire panel on my phone including the AUX.
Can someone please help me? The Aux is our garage door.
This will toggle the Aux output number 2. From memory you’ll need to set up how long it gets toggled for through the Ness alarm system. I have mine set for 1 second. Also not that because I have it set to toggle you can stop the door by toggling it a second time.
Cheers
Flatstrap
New to this so apologies for dragging up an old post.
I have a ness alarm working on the dashboard after adding the code to the yaml file but I cannot get the aux outputs working. Where do I add this code and how do I configure it?
Hi Digitalization,
Sorry it’s taken a while to get back to you. The Auxiliary contacts are operated by calling a service I have it setup in a script, it’s in my “config/scripts/” folder which is referred to from my configuration file.
The file is simply called toggle_garage.yaml
To operate it I simply have a button call the script.
