I need some assistance setting up an automation to keep my nest thermostat in “home mode” while any one is home by using device tracker.
Not sure if my config is formatted correctly, for if only one of us is home.
The following is my config, if I trigger the automation manually it works, if my phone goes from away to home it works, but it doesn’t trigger / stay on if I’m already home and nest switches to away mode?
Nice work, I had been planning on doing this and finally got around to writing the automation.
Question I have is, is this needed because Nest only assumes someone is home or away based on the sensor of the thermostat actually seeing motion or not seeing motion for x period of time? Just curious because it would be nice to set presence another way so that you don’t have to wait for the eco mode to go on.
