With the new API for Nest, has anyone figured out a way to detect the House “away Mode”
there was previously an entity sensor.downstairs_away_mode which i use to check for state change as a trigger or condition but i can no longer see this. just wondered if anyone else is seeing these same or has found a workaround.
From what I could tell, the API does not (yet at least) report the ‘home’ and ‘away’ states.
thanks suspected as much… lets hope its coming
Waiting for this entity as well!
I just had to upgrade from legacy Nest integration to the newer version hooked in with google, and i lost a lot of sensors. Is this normal? any way to get some of those back, specifically the home/away? I had a lot of integrations based on using that sensor
