Nest binary sensors don't trigger
Hello there,
I’ve search all over the forum, and can’t seem to find a definitive answer as to whether I should expect the Nest API to update the binary sensors in HA for things like motion_detected or not.
I have the auth configured, I can get the camera image/live stream, but when the camera detects motion and I receive a push notification from the iOS Nest app, the binary_sensor value does not change from ‘off’ to ‘on’ as expected.
Is this not working, or am I doing something wrong?
I do not see any errors in the log indicating any issues communicating with the Nest API, so I am left at a loss to explain why the binary_sensor isn’t triggered.
And yes I have a paid subscription for Nest Aware service, which I understand is required for the motion detection feature to be enabled on Nest’s side.
So far from what I can tell, the sensors are all queried when home assistant first starts up, but then never again.
Just following up here that sometimes I see the binary_sensor state change from the Nest API, and sometimes I don’t. Unclear what is causing the issue, and whether it’s a problem from Nest’s API or with HA itself, or somewhere in between.
Also not working for me. Anyone figured it out?
Has anyone found out why this happens or if we can improve the update frequency?
Also not working for me. I think this has more to do from the Nest side than HA.
Not working for me, either. Anyone found a solution?
Not working for me either. Really need this to be working for the automations I want to achieve
I signed up for nest Aware and now I get much more frequent updates(almost too sensitive motion sensor actually). I am a bit disappointed with the person detection, which doesn’t work well when it’s dark outside (which is when it is needed most ;))
One thing to remember is when you create the Nest developer account for Home Assistant, allow person/motion detection data to be accessed by Home Assistant
This problem has been diagnosed and fixed via a patch to HA which you can obtain here: As this is an experimental patch it requires somewhat intricate setup unfortunately (e.g. installing either Python or a container runtime). I don’t know if/when this patch will be merged into HA itself; if you see an opportunity to advocate for that, please do.
best,
-J
