Nest camera does not seem to be working.
Currently on 0.34.4
I followed the steps outlined here and was able to enter in the pin. However, when i go to my frontend it shows error loading image. My logs have the following:
16-12-07 11:05:20 aiohttp.web: Error handling request
File “/var/opt/homeassistant/deps/aiohttp/server.py”, line 265, in start
yield from self.handle_request(message, payload)
File “/var/opt/homeassistant/deps/aiohttp/web.py”, line 96, in handle_request
resp = yield from handler(request)
File “/usr/lib/python3.4/asyncio/coroutines.py”, line 143, in coro
res = yield from res
File “/usr/local/lib/python3.4/dist-packages/homeassistant/components/http/init.py”, line 403, in handle
result = yield from result
File “/usr/local/lib/python3.4/dist-packages/homeassistant/components/camera/init.py”, line 186, in get
response = yield from self.handle(request, camera)
File “/usr/local/lib/python3.4/dist-packages/homeassistant/components/camera/init.py”, line 204, in handle
image = yield from camera.async_camera_image()
File “/usr/local/lib/python3.4/dist-packages/homeassistant/components/camera/init.py”, line 91, in async_camera_image
None, self.camera_image)
File “/usr/lib/python3.4/asyncio/futures.py”, line 388, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.4/asyncio/tasks.py”, line 286, in _wakeup
value = future.result()
File “/usr/lib/python3.4/asyncio/futures.py”, line 277, in result
raise self._exception
File “/usr/lib/python3.4/concurrent/futures/thread.py”, line 54, in run
File “/usr/local/lib/python3.4/dist-packages/homeassistant/components/camera/nest.py”, line 98, in camera_image
url = self.device.snapshot_url
File “/var/opt/homeassistant/deps/nest/nest.py”, line 1250, in snapshot_url
if self._device[‘snapshot_url’] != SIMULATOR_SNAPSHOT_URL:
KeyError: ‘snapshot_url’
I had the same problem and it was because I checked “Camera” and not “Camera + Images” in permissions. I had to uncheck “Camera” and then I was able to check “Camera + Images.”
Cool! Yeah, I did the same thing, but I think you can also click the “Allow” button on the notification you get in the Nest app to allow the additional permissions.
What do you mean by forced a reconfiguration? I’m stuck in a similar boat it looks like and can’t get the configuration card on the gui to comeback so I can enter the pin. What steps did you take?
THat worked for me. I went back to nest developers and remove camera permissions. Added camera+image. Back to HASS. Deleted nest.conf. Restart HASS. Configured nest with new PIN. Restart. All good.
Agree- Same issue here, due to following instructions. I then change permissions , then restart de HA and thats it… is working. but still image though…
