Have two nest cameras (doorbell and home hub max) setup with Home Assistant using setup on the integration page. Suddenly they have stopped working and I am getting the following error in the logs:
Logger: homeassistant.components.stream.worker
Source: components/stream/worker.py:409
Integration: Stream (documentation, issues)
First occurred: 00:32:22 (59 occurrences)
Last logged: 00:56:49
Error opening stream rtsps:// (long link here I assume to camera)
I can still see the cameras functioning normally in the Nest app. I did move Home Assistant over to a new RP4 and SSD using a backup yesterday, though the cameras have been working perfectly fine since then until just now.
Tried a reboot of Home Assistant and that hasn’t helped. Any help on this would be appreciated. If you need any further info please let me know. Cheers
EDIT: The one thing I have also changed recently is the lovelace card to camera_view: live. Tried changing back but still getting nothing.
I think they might have changed the API - i can still get to it through the Nest app. Video stream through VLC no longer works (broke frigate as well) , and you can access the stream through their HTML link if you set the stream to public.
Occurred about 1 PM MDT today. Next step is to look through the google developer portal to see if they changed the API
