Hi All,
as HA now forces all cams to be on WebRTC stream, this unfortunately has broken all NEST cams.
I thought it it’s broken, HA would revert back to previous stream protocol?
I am not sure what it was using, but assuming it was RSTP, is there a way to force the stream to use RSTP?
Yeah, two things: (1) WebRTC should work well for nest cameras, it does for mine and so if we can make it work you’d probably like it better and (2) fallback should work to HLS/RTSP. So either way this is not working as intended and a bug. Can you report an issue at Reporting issues - Home Assistant with additional details? It may require getting additional logs from the developer console to understand what is happening in the browser
