Nest Configuration error after .52 Upgrade
I’m getting a nest component error after upgrading to 0.52 (also get an error on 0.52.1). I didn’t change anything in my config.
Anybody else have this problem?
Here is my error log-
2017-08-30 14:12:14 ERROR (MainThread) [homeassistant.setup] Error during setup of component nest
  File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/connection.py", line 141, in _new_conn
    (self.host, self.port), self.timeout, **extra_kw)
  File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/util/connection.py", line 60, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/lib/python3.6/socket.py", line 743, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
  File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py", line 600, in urlopen
    chunked=chunked)
  File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py", line 345, in _make_request
    self._validate_conn(conn)
  File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py", line 844, in _validate_conn
    conn.connect()
  File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/connection.py", line 284, in connect
    conn = self._new_conn()
  File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/connection.py", line 150, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x73dd5670>: Failed to establish a new connection: [Errno -3] Try again
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 438, in send
    timeout=timeout
  File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py", line 649, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/util/retry.py", line 388, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
requests.packages.urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='developer-api.nest.com', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x73dd5670>: Failed to establish a new connection: [Errno -3] Try again',))
  File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 194, in _async_setup_component
    component.setup, hass, processed_config)
  File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
    future.result()
  File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
    raise self._exception
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/components/nest.py", line 134, in setup
    setup_nest(hass, nest, config)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/nest.py", line 99, in setup_nest
    hass.data[DATA_NEST] = NestDevice(hass, conf, nest)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/nest.py", line 166, in __init__
    self.local_structure = [s.name for s in nest.structures]
  File "/usr/lib/python3.6/site-packages/nest/nest.py", line 1654, in structures
    for stid in self._status[STRUCTURES]]
  File "/usr/lib/python3.6/site-packages/nest/nest.py", line 1604, in _status
    value = self._get("/")
  File "/usr/lib/python3.6/site-packages/nest/nest.py", line 1587, in _get
    return self._request('GET', path)
  File "/usr/lib/python3.6/site-packages/nest/nest.py", line 1565, in _request
    data=data)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 518, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 639, in send
    r = adapter.send(request, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 502, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='developer-api.nest.com', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x73dd5670>: Failed to establish a new connection: [Errno -3] Try again',))
yep. Have nest smoke detectors…getting it too.
Looking a little more into it, it seems like nothing external is working…
What I mean by that is, I can’t connect to dark rain, I have a couple “cameras” that are weather maps that aren’t getting pulled down, my smtp notification isn’t working, etc.
Is this the same as you?
I double checked and I can ping websites such as google.com from the terminal via ssh. Not exactly sure what is going on.
Hi @stallion11885,
I seem to have the a similar if not the same issue.
Any idea what is going on? did someone raise an issue?
2017-09-16 19:51:56 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.office_thermostat_operation_mode fails
    chunked=chunked)
    conn.connect()
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x730a48d0>: Failed to establish a new connection: [Errno -3] Try again
    timeout=timeout
requests.packages.urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='firebase-apiserver08-tah01-iad01.dapi.production.nest.com', port=9553): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x730a48d0>: Failed to establish a new connection: [Errno -3] Try again',))
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 225, in async_update_ha_state
    yield from self.hass.async_add_job(self.update)
    future.result()
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/nest.py", line 130, in update
    self._state = getattr(self.device, "mode")
  File "/usr/lib/python3.6/site-packages/nest/nest.py", line 339, in mode
    return self._device.get('hvac_mode')
  File "/usr/lib/python3.6/site-packages/nest/nest.py", line 275, in _device
    return self._devices[THERMOSTATS][self._serial]
  File "/usr/lib/python3.6/site-packages/nest/nest.py", line 200, in _devices
    return self._nest_api._devices
  File "/usr/lib/python3.6/site-packages/nest/nest.py", line 1619, in _devices
    return self._status[DEVICES]
  File "/usr/lib/python3.6/site-packages/nest/nest.py", line 1578, in _request
    data=data)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='firebase-apiserver08-tah01-iad01.dapi.production.nest.com', port=9553): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x730a48d0>: Failed to establish a new connection: [Errno -3] Try again',))
2017-09-16 19:51:56 ERROR (MainThread) [homeassistant.helpers.entity] Update for binary_sensor.downstairs_thermostat_is_using_emergency_heat fails
    chunked=chunked)
    conn.connect()
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x756c9a70>: Failed to establish a new connection: [Errno -3] Try again
    timeout=timeout
requests.packages.urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='firebase-apiserver08-tah01-iad01.dapi.production.nest.com', port=9553): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x756c9a70>: Failed to establish a new connection: [Errno -3] Try again',))
    future.result()
  File "/usr/lib/python3.6/site-packages/homeassistant/components/binary_sensor/nest.py", line 105, in update
    self._state = bool(getattr(self.device, self.variable))
  File "/usr/lib/python3.6/site-packages/nest/nest.py", line 398, in is_using_emergency_heat
    return self._device.get('is_using_emergency_heat')
    data=data)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='firebase-apiserver08-tah01-iad01.dapi.production.nest.com', port=9553): Max retries exceeded with url: / (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x756c9a70>: Failed to establish a new connection: [Errno -3] Try again',))
same here nest works for a bit after reinstall than back to square one after restart hassio
2017-10-08 12:24:29 ERROR (MainThread) [homeassistant.setup] Error during setup of component nest
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connection.py”, line 141, in _new_conn
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/util/connection.py”, line 60, in create_connection
File “/usr/lib/python3.6/socket.py”, line 743, in getaddrinfo
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py”, line 600, in urlopen
chunked=chunked)
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py”, line 345, in _make_request
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py”, line 844, in _validate_conn
conn.connect()
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connection.py”, line 284, in connect
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connection.py”, line 150, in _new_conn
self, “Failed to establish a new connection: %s” % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x740902f0>: Failed to establish a new connection: [Errno -3] Try again
File “/usr/lib/python3.6/site-packages/requests/adapters.py”, line 438, in send
timeout=timeout
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py”, line 649, in urlopen
File “/usr/lib/python3.6/site-packages/requests/packages/urllib3/util/retry.py”, line 388, in increment
requests.packages.urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘developer-api.nest.com’, port=443): Max retries exceeded with url: / (Caused by NewConnectionError(’<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x740902f0>: Failed to establish a new connection: [Errno -3] Try again’,))
File “/usr/lib/python3.6/site-packages/homeassistant/setup.py”, line 194, in _async_setup_component
File “/usr/lib/python3.6/asyncio/futures.py”, line 331, in iter
File “/usr/lib/python3.6/asyncio/tasks.py”, line 244, in _wakeup
future.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 244, in result
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 55, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/nest.py”, line 134, in setup
File “/usr/lib/python3.6/site-packages/homeassistant/components/nest.py”, line 99, in setup_nest
File “/usr/lib/python3.6/site-packages/homeassistant/components/nest.py”, line 166, in init
File “/usr/lib/python3.6/site-packages/nest/nest.py”, line 1654, in structures
File “/usr/lib/python3.6/site-packages/nest/nest.py”, line 1604, in _status
File “/usr/lib/python3.6/site-packages/nest/nest.py”, line 1587, in _get
return self._request(‘GET’, path)
File “/usr/lib/python3.6/site-packages/nest/nest.py”, line 1565, in _request
data=data)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 518, in request
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 639, in send
File “/usr/lib/python3.6/site-packages/requests/adapters.py”, line 502, in send
requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘developer-api.nest.com’, port=443): Max retries exceeded with url: / (Caused by NewConnectionError(’<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x740902f0>: Failed to establish a new connection: [Errno -3] Try again’,))
do you still have this issue. I am at ha 55 on hassio and still get the same errors?
Yes mate … if I reinstall it works for two minutes once you restart hassio it is back to square one … Anyone have anyone solutions ??
all sorted now and stable … did u solved ur problem ?
Nope I still the same errors. Did you change anything specific?
I updated everything from command prompt once all done rebooted and nest came back in hassio home page since than all fine…
Now it is telling me update to .56.1 available but I am putting it off as everything is working fine
I’m also having the same issue. I’m on version 57.2 and still getting this issue. I’m on Hass.io so I cannot do anything via the command line. Did anyone manage to get this working? if so how?
Ok so I’ve had a bit of a play around. I have added the sensors and monitiored conditions to my yaml so it now looks like this.
nest:
  client_id: <client_id>
  client_secret: <client_secret>
  sensors:
    monitored_conditions:
      - co_status
      - smoke_status
      - battery_health
I’m sure adding sensors to the yaml wasn’t manditory but i’ve added it now and it now seems to be working, I’m no longer getting the error as described in post 1.
hope this helps :grinning:
UPDATE
it’s still not working, I’m getting these errors again.:disappointed_relieved:
Same error for me on 0.53.0.
This is a little frustrating. I moved my PI to my regular 192.168.1.* subnet and everything has worked without a hitch for a couple months. I added a zwave device today and had to restart home assistant and it stopped working today.
Same errors-
Nothing can get to anything on the internet-
Nest
Weather updates
A couple Weather Radar “Cameras” I have set up
smtp notifications
etc.
Everything internal to my network works just fine.
I disabled the nest component completely, same thing, nothing requiring internet access works.
So this really has nothing to do with Nest besides the fact that it requires internet access to work, and that is broken.
I updated to 57.3 to see if there had been any fixes…nope.
Dang!
Anybody have any ideas? Or at least can point me in some direction?
I have looked at my error logs, and they basically just have a bunch of errors of different components trying to access the internet.
I will keep looking, but any help would be appreciated.
Did you ever get this working? I’m running into the same issue.
I’ve been getting this issue for awhile now as well. Sometimes I can get it to start up and not have the issue, but eventually it’ll start having problems. My Nest also acts strange when connected to Hass. It will frequently change the home/away mode for apparently no reason, even with no automations or anything being triggered. Removing it from Hass stops that from happening.
I really wonder if we need https://github.com/jkoelker/python-nest/issues/109 but it seems nobody is currently planning on doing it.
