Since moving over to Hass.io I have been having periodic drop outs from my Nest Thermostat.
I would see:
Invalid Config:
The Following components and platforms could not be setup.
Nest.
Since the nest setup was transferred over from my old UnRaid Docker install of Home-Assistant, I thought maybe it was causing an issue (I just copy/pasted the nest entry from the old configuration.yaml to the new one.)
I removed the original entry from my nest account and recreated a new one, and went through the setup process again from scratch.
Now it never setups correctly, even after several reboots. It never asks me to validate as it should.
I have triple checked the yaml files and Im positive its setup as directed here.
Anyone have any suggestions.
Im running Hass.io 0.63.2
I get the following errors in my logs for this.
Log Details (ERROR)
Fri Feb 16 2018 15:38:11 GMT-0500 (Eastern Standard Time)
Error during setup of component nest
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 60, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.6/socket.py", line 745, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
conn.connect()
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 284, in connect
conn = self._new_conn()
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 150, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x731c66f0>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='developer-api.nest.com', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x731c66f0>: Failed to establish a new connection: [Errno -3] Try again',))
File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 148, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.6/asyncio/futures.py", line 332, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/nest.py", line 134, in setup
setup_nest(hass, nest, config)
File "/usr/lib/python3.6/site-packages/homeassistant/components/nest.py", line 99, in setup_nest
hass.data[DATA_NEST] = NestDevice(hass, conf, nest)
File "/usr/lib/python3.6/site-packages/homeassistant/components/nest.py", line 166, in __init__
self.local_structure = [s.name for s in nest.structures]
File "/usr/lib/python3.6/site-packages/nest/nest.py", line 1654, in structures
for stid in self._status[STRUCTURES]]
File "/usr/lib/python3.6/site-packages/nest/nest.py", line 1604, in _status
value = self._get("/")
File "/usr/lib/python3.6/site-packages/nest/nest.py", line 1587, in _get
return self._request('GET', path)
File "/usr/lib/python3.6/site-packages/nest/nest.py", line 1565, in _request
data=data)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 508, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='developer-api.nest.com', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x731c66f0>: Failed to establish a new connection: [Errno -3] Try again',))
