Nest Doorbell (Battery) + Frigate
Hello Everyone,
I’m hoping there is many of you smarter than me that have figured this out. I have searched all over and have not found a reliable method to capture the new Nest Doorbell (Battery) WebRTC livestream URL to add this into Frigate.
What my end goal is:
I’m hoping to utilize the WebRTC stream and pass that into Frigate, to then use the entities that Frigate will create to pass them through the scripts created in HA that pass a camera entity to PipUp on my Chromecast with Google TV (Android TV) - from the thread that Sean Blanchfield created here.
I’m starting this thread in hopes that someone has run into this issue, and has a potential solution for it.
I have tried what @allenporter mentioned here without utilizing Frigate at all and trying to just share a link to a HA dashboard with a single entity streaming my doorbell through the Nest Integration, but this did not work on the PipUp app on the Android TV as HA requires some form of authentication/user input, even when bypassing the login screen, it still requires me to use some form of input (and I’m not overly comfortable with bypassing the login screen outside of my local network!).
Hoping someone has ideas here!
Thank you!
Hey,
I have the same problem and have not resolved this yet. However, in my investigations I did come across this project which MAY help us achieve our goals.
https://nest-rtsp.jak.guru/
If I get this up and running successfully I will post back here. If you could do the same it would be appreciated.
Cheers
Don’t bother with the https://nest-rtsp.jak.guru/ project for now. I spent a day pulling my hair out trying to set it up, only to figure out it doesn’t support the newer WebRTC cameras yet.
There’s an open issue that hasn’t been updated in over a year.
https://bugs.jak.guru/show_bug.cgi?id=6
Hopefully Files · 2.0.x · Jak Guru / Nest RTSP · GitLab will work soon there is a WIP
Any news about this?
I was able to use go2rtc (bundled with frigite) to get a stream into frigate
I got the require tokens from here:
https://developers.google.com/nest/device-access/get-started
Then I used the Nest option in go2rtc to pull links that i then added to the temporary streams sections
Can you share your configurations?
Frigate Config
mqtt:
  enabled: true
  host: 127.0.0.1
  port: 1883
  topic_prefix: frigate
  client_id: frigate
  user: ###
  password: ###
ffmpeg:
  hwaccel_args: preset-vaapi
  output_args:
    record: preset-record-generic-audio-aac
record:
  enabled: true
  retain:
    days: 3
    mode: all
  events:
    retain:
      default: 14
      mode: motion
snapshots:
  enabled: true
  retain:
    default: 14
objects:
  track:
    - person
    - dog
    - cat
#    - car
detectors:
  coral:
    type: edgetpu
    device: pci:0
#  ov:
#    type: openvino
#    device: AUTO
#    model:
#      path: /openvino-model/FP16/ssdlite_mobilenet_v2.xml
#model:
#  width: 300
#  height: 300
#  input_tensor: nhwc
#  input_pixel_format: bgr
#  labelmap_path: /openvino-model/coco_91cl_bkgr.txt
birdseye:
  enabled: true
  layout:
    max_cameras: 1
cameras:
  driveway_camera:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/driveway_camera?video=h264&audio=opus
        #  input_args: preset-rtsp-restream
          roles:
            - detect
            - record
    detect:
      height: 1080
      width: 1920
      fps: 5
    motion:
      threshold: 40
      contour_area: 10
      improve_contrast: 'true'
    zones:
      Driveway:
        coordinates: 0.347,0.229,0.139,1,1,1,0.736,0.189
      Front_Yard:
        coordinates: 0.757,0.23,0.832,0.454,1,1,1,0.74,1,0.248,0.898,0.242
      Side:
        coordinates: 0.195,0.367,0,0.864,0.001,0.998,0.134,0.995,0.314,0.327
      Street:
        coordinates:
          -0.004,0.321,0,0.436,0.131,0.376,0.313,0.304,0.343,0.215,0.457,0.2,0.759,0.172,0.771,0.23,1,0.243,1,0.201,1,0.078,0.927,0.052,0.78,0.034,0.568,0.037,0.378,0.082,0.17,0.179,0.066,0.255
        inertia: 3
    review:
      alerts:
        required_zones:
          - Driveway
          - Side
      detections:
        required_zones:
          - Front_Yard
          - Street
  front_yard_camera:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/front_yard_camera?video=h264&audio=opus
          roles:
            - detect
            - record
    detect:
      height: 1080
      width: 1920
      fps: 5
    motion:
      threshold: 55
      contour_area: 10
    objects:
      filters:
        car: {}
    zones:
      Front_Yard:
        coordinates:
          0.285,0.191,0.091,0.361,0.147,0.485,0.018,0.658,0.017,0.797,0.134,0.999,0.36,0.999,0.934,1,0.933,0.732,0.899,0.47,0.868,0.342,0.846,0.286,0.632,0.227,0.504,0.192,0.354,0.191
      Driveway:
        coordinates: 0.277,0.189,0.168,0.201,0.05,0.328,0.083,0.357
      Street:
        coordinates:
          0.995,0.174,0.998,0.339,0.855,0.282,0.581,0.201,0.372,0.178,0.257,0.18,0.154,0.193,0.189,0.118,0.283,0.079,0.374,0.052,0.533,0.055,0.679,0.07,0.816,0.103,0.926,0.152
    review:
      alerts:
        required_zones: Front_Yard
      detections:
        required_zones:
          - Driveway
          - Street
go2rtc:
  rtsp:
    username: ###
    password: ###
  streams:
    driveway_camera:
      - nest:?client_id=###&client_secret=###&device_id=###&project_id=###&refresh_token=###
    front_yard_camera:
camera_groups: {}
Here’s my full config file
The battery doorbell doesnt handle 24/7 recording and will die in a few hours but the other newer nest cameras work fine with it
I tried this, managed to get all the creds but Im still getting a tone of errors in the friaget log. Im using go2rtc 1.8.5 and frigate (0.13.2-6476f8a). Im using a Nest Wired doorbell.
cameras:
  Doorbell-camera:
    enabled: true
    mqtt:
      timestamp: false
      bounding_box: false
      crop: true
      quality: 100
      height: 1080
    ffmpeg:
      inputs:
      - path: rtsp://127.0.0.1:8554/Doorbell-camera?video=h264&audio=opus
        roles:
        - detect
go2rtc:
  streams:
    Doorbell-camera:
    - nest:?client_id=xxx&client_secret=xxx&device_id=xxx&project_id=xxx&refresh_token=xxx
I got the device ID by making this call using the access token
curl -X GET 'https://smartdevicemanagement.googleapis.com/v1/enterprises/f84b68fa-9350-497b-962b-1b64ce8c1f52/devices'
-H 'Content-Type: application/json'
-H 'Authorization: Bearer  <accesstoken>'
Which gave me
"name": "enterprises/<clientid>devices/<deviceId>"
Heres what im getting in frigate log
2024-05-31 11:52:53.948029046  [2024-05-31 11:52:53] frigate.video                  ERROR   : Doorbell-camera: Unable to read frames from ffmpeg process.
2024-05-31 11:52:53.948372747  [2024-05-31 11:52:53] frigate.video                  ERROR   : Doorbell-camera: ffmpeg process is not running. exiting capture thread...
2024-05-31 11:53:03.050464272  [2024-05-31 11:53:03] watchdog.Doorbell-camera       ERROR   : Ffmpeg process crashed unexpectedly for Doorbell-camera.
2024-05-31 11:53:03.050640603  [2024-05-31 11:53:03] watchdog.Doorbell-camera       ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
2024-05-31 11:53:03.050792927  [2024-05-31 11:53:03] ffmpeg.Doorbell-camera.detect  ERROR   : [rtsp @ 0x55d384ef2100] method DESCRIBE failed: 404 Not Found
2024-05-31 11:53:03.050944777  [2024-05-31 11:53:03] ffmpeg.Doorbell-camera.detect  ERROR   : rtsp://127.0.0.1:8554/Doorbell-camera?video=h264&audio=opus: Server returned 404 Not Found
Here is my device properties
        "sdm.devices.traits.CameraLiveStream": {
          "maxVideoResolution": {
            "width": 640,
            "height": 480
          "videoCodecs": [
            "H264"
          "audioCodecs": [
            "AAC"
          "supportedProtocols": [
            "RTSP"
In go2rtc log inside frigate
2024-05-31 11:58:29.167216938  11:58:29.167 WRN [rtsp] error="streams: nest: wrong status: 400 Bad Request" stream=Doorbell-camera
2024-05-31 11:58:39.284705683  11:58:39.284 WRN [rtsp] error="streams: nest: wrong status: 400 Bad Request" stream=Doorbell-camera
2024-05-31 11:58:48.389646928  11:58:48.389 WRN [rtsp] error="streams: nest: wrong status: 400 Bad Request, nest: wrong status: 429 Too Many Requests" stream=Doorbell-camera
Are you using the older nest doorbell thats used with the nest app?
I only have the newer ones that this worked with and dont really know if it works with the older models.
The other link in this thread should work for the older nest models (maybe… i wouldnt know tbh)
Also for the config part, you can change ‘opus’ to ‘aac’ or ‘copy’ since it seems your camera is using AAC and not OPUS like the newer ones and probably the 1080 height to 480
Did you get the wired doorbell to work? Im running into the same issues you showed.
Hey - I ran into this and resolved it by doing the following:
Summary: I installed and used to home assistant go2rtc add-on to create the go2rtc config lines in the frigate.yaml file.
go2rtc:
  streams:
    cam1:
      - nest:?client_id=redacted&client_secret=redacted&project_id=redacted&protocols=WEB_RTC&refresh_token=redacted
    cam2:
Then for each of the cameras in the frigate.yaml file, i added the lines below into the camera config sections (where cam1 is the camera name):
cam1:
  ffmpeg:
    inputs:
      - path: rtsp://127.0.0.1:8554/cam1?video=all&audio=all
Details:
  1. get the go2rtc add-on from this repository: https://github.com/AlexxIT/hassio-addons and install it/start it
  2. Open the web UI
  3. click on “Add”
  4. click on “Google Nest”
  5. You are presented with a form to fill out and the following steps will guide you into finding the required info (four items: client_id, client_secret, refresh_token, project_id)
  6. To find the client_id and client_secret, you need to log into the https://console.cloud.google.com using the google account associated with your “google nest” integration (it is assumed that you already have this installed into home assistant - if not, do that first by following the very detailed home assistant documentation for the google nest integration.)
  7. Once signed into the google cloud console, choose the project name that is associated with the google nest integration (some people have more than one google project - for example if you installed the google assistant integration, you would have two projects - ensure you have selected the project associated with the google nest integration. Then select the API APIs and Services button.
  8. click on “credentials” on the left hand panel.
  9. you will be presented with the Oauth 2.0 client ID link which you created while installing the google nest integration - click on that link.
  10. On the top right, you will see, under “Additional Information”, the Client_ID (copy and paste the whole thing onto your PC in notepad or something similar and label it Client ID)
  11. Just below the client ID under “Client Secrets” you will find the client_secret copy that whole item and paste into your notepad doc labeling it “client_secret”
  12. We still are required by go2rtc add-on to find 2 more items: “refresh_token” and “project_id” - I think the easiest method to find these is to open and read a hidden folder in the home assistant file system. The file is called “core_config” and it’s located in the hidden folder: “/config/.storage” - I opened this file by installing the “Samba Share” add-on and mapping to it using my windows PC. I have not included the steps to do this here as it’s kinda out of scope - but this should not be difficult for the average home assistant user. There may be a better way of opening that file to read it but I used notepad and opened it over a network share.
  13. Once in the file, search for the string exactly as it is typed in bold/italics including the quotes and { characters: {“auth_implementation”:“nest”
  14. when you find that string you should be on the record which contains both the “refresh_token” and the “project_id” required by the go2rtc add-on. On that record, look for the item labeled “project_id” it should be a series of around 32 characters separated by dashes. Further alon the record, you will also find the “refresh_token” which is a string of about 100 random characters.
  15. copy and past and label these on your PC.
  16. Now you should be ready to enter the four items into the go2rtc add-on form (hass settings/add-ons/go2rtc/add/google nest).
  17. once entered correctly, you can click on “Login” and wait for a sec - the add-on will return the “go2rtc / streams” content as described above in the summary for each nest camera. Enter the content exactly as described above but with the streams filled in per the go2rct add-on results.
  18. Fill in the content for each camera exactly as described in the 2nd half of the summary.
  19. Save the updated frigate.yaml file and restart the frigate add-on.
I hope this helps some poor sole who doesn’t want to waste 40 hours (instead only spending around 4 or 5 hours :slight_smile: I think it will work for any google camera which is currently viewable from within the “Google Home” app having been migrated from the “Nest” app.
