Nest : Error and no message
Hi all! New user here.
I’ve installed HAOS onto a new NUC (virtually with Proxmox) It’s all working fine, and I wanted to connect my Nest thermostat. I meticulously followed the guide on here, including paying $5 for access, and I get to the very final step to link
When I click “Link Account”, the tab just goes to a blank window and if I flip back to the HA tab, it just says ‘Error’, but no descriptive text.
Also I noticed this permissions screen in the tutorial, which I’m not getting
Instead, mine goes from the bypassing the lack of secure network, straight to the final permissions screen.
I have had a look around here, and changed things like turning off IP6 etc but no luck.
Any ideas? :frowning: Thanks
The log prompts an error and says this
Logger: aiohttp.server
Source: /usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py:403
First occurred: 11:13:02 am (3 occurrences)
Last logged: 11:17:32 am
Error handling request
File “/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py”, line 433, in _handle_request
resp = await request_handler(request)
File “/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py”, line 504, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py”, line 117, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 85, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/forwarded.py”, line 100, in forwarded_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 28, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 80, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 236, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/headers.py”, line 31, in headers_middleware
response = await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 148, in handle
result = await handler(request, **request.match_info)
File “/usr/src/homeassistant/homeassistant/components/http/decorators.py”, line 63, in with_admin
return await func(self, request, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 170, in get
return await super().get(request, flow_id)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 96, in get
result = await self._flow_mgr.async_configure(flow_id)
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 293, in async_configure
result = await self._async_handle_step(
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 389, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File “/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py”, line 315, in async_step_creation
token = await self.flow_impl.async_resolve_external_data(
File “/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py”, line 172, in async_resolve_external_data
return await self._token_request(
File “/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py”, line 209, in _token_request
resp.raise_for_status()
File “/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py”, line 1005, in raise_for_status
raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 401, message=‘Unauthorized’, url=URL(‘https://www.googleapis.com/oauth2/v4/token’)
Fixed it. There must have been something off with my installation of HAOS. I reinstalled it then it all worked!
