Nest event problem
Hi trying to get a notification every time the nest away_mode switches but can’t see to
What is working: Tasker http post to turn away mode on
via
http://myip:8123/api/services/climate/set_away_mode?api_password=mypassword
json{“entity_id”:“climate.hallway”, “away_mode”:“on”} or “off”
turns the nest away mode on/off. Great.
Not working: configuration yaml
    notify:
      - name: mypushbullet
        platform: pushbullet
        api_key: mykey
    automation:
    - alias: nesthome
      initial_state: True
      hide_entity: False
        platform: state
        entity_id: climate.hallway
        state: 'away_mode:off'
        service: notify.mypushbullet
        data_template:
            title: "Nest"
            message: 'Nest set to Home @ {{now().strftime("%H:%M:%S [%Y-%m-%d]")}}'
    - alias: nestaway
      initial_state: True
      hide_entity: False
        platform: state
        state: 'away_mode:on'
        data_template:
            title: "Nest"
            message: 'Nest set to Away @ {{now().strftime("%H:%M:%S [%Y-%m-%d]")}}
neither fire. yet if i trigger the item manually a pushullet notification results. it’s as though the trigger state entity isnt registering correctly.
Any thoughts as to what is wrong?
Can you post your config with formatting maintained. See the first post for instructions
notify:
    api_key: mykey
automation:
- alias: nesthome
  initial_state: True
  hide_entity: False
    platform: state
    data_template:
        title: "Nest"
- alias: nestaway
  initial_state: True
  hide_entity: False
    platform: state
    data_template:
        title: "Nest"
        message: 'Nest set to Away @ {{now().strftime("%H:%M:%S [%Y-%m-%d]")}}'
The trigger is wrong. Since “away_mode” is an attribute, I believe you’ll need to use a template trigger instead
  platform: template
  value_template: "{{ is_state_attr('climate.hallway', 'away_mode', 'off') }}"
Your automations are not triggering as climate.hallway does not have a state “away_mode:off” Away mode is an attribute of climate.hallway not a state. That is why it is in the third column of the states page and not the second.
Here is how I implemented this…
Create a template sensor:
    sensors:
      hallway_away_mode:
        entity_id: climate.downstairs
        value_template: "{{ is_state_attr('climate.hallway', 'away_mode', 'on') }}"
From there replace the following in your above automations under trigger:
entity_id from ‘climate.hallway’ to ‘sensor.hallway_away_mode’
and
state: from ‘away_mode:off’ to ‘false’ in the first automation
state: from ‘away_mode:on’ to ‘true’ in the second automation
No need for the extra sensor. Just use a template trigger like I mentioned above.
Yep, multiple ways to skin a cat. I just like sensor option as then I can keep a history of that away_mode usage. Also helpful in troubleshooting my automation as I have conditions based on the away_mode. Reviewing the logbook to see why it didn’t trigger and I can check the away_mode status when it should have triggered.
platform: template
value_template: "{% if is_state_attr('climate.hallway', 'away_mode', 'on') %}true{% endif %}"
Is working. Thanks for all the help
Fair enough. Although you can handle conditions and log attribute changes to the logbook without the extra sensor as well. I already have enough sensors, so I prefer to avoid creating more that just duplicate data. Nice thing is, HASS is flexible enough to let you do it whichever way you want :sunglasses:.
