Nest Fan Script
Hi there
I’m looking for a hand with automating my Nest in a script.
Here is what I have:
script:
  fan_off_timer:
    sequence:
      - delay:
          minutes: 30
      - service: climate.set_fan_mode
          entity_id: climate.entryway
          fan_mode: 'auto'
  fan_off_now:
    sequence:
          fan_mode: 'auto'
  fan_on:
    sequence:
          fan_mode: 'on'
      - service: script.turn_on
          entity_id: script.fan_off_timer
For some reason, I the fan doesn’t run. I’ve also tried to enable the fan with Nest but that always fails for me.
fan:
  - platform: nest
Thank you for your help
Sorry, don’t mean to resurrect an old thread, but I was looking for the same and figured it out on my own. I wanted a script (or scripts) to invoke, rather than just an automation; for those who follow, see working config below:
script:
  nest_fan_on:
    alias: Nest Fan On
    sequence:
        entity_id: climate.hallway_nest
          fan_mode: 'on'
  nest_fan_off:
    alias: Nest Fan Off
    sequence:
          fan_mode: 'auto'
switch:
    switches:
      nest_fan:
        friendly_name: "Nest Fan"
        value_template: "{{ is_state('Nest Fan', 'on') }}"
        turn_on:
          entity_id: script.nest_fan_on
        turn_off:
          entity_id: script.nest_fan_off
Ranunculales. Does your fan remain on until you manually turn it back to auto? I have a similar automation but my Nest reverts back to auto after thirty minutes.
The Nest API has a fan duration setting but the HA climate service does not. I suspect Nest or HA is defaulting to a 30 minute duration, but I have no way to change it.
I’m looking at this right now too. It looks like HA may only have the ability to turn the fan “on” and off (“auto”) but I have found in the Google nest docs that there is a setTimer function in the nest API that allows someone to POST a runtime to the thermostat.
