Both the Nest Hub and the Amazon Echo Show 5 or 8 are on sale in the UK at the moment and i’m wondering which is best for integration into Home Assistant.
Specifically things I’m looking to do:
When my doorbell rings show a video stream from the camera on it.
Show a HA style dashboard so I can click buttons to turn some lights on/off
Also I see that Nest Hub can stream Netflix so that got me thinking can either of them stream Plex or stream from HDHomeRun?
I do this with my own camera, that provides a suitable stream source - sending to my Google/Nest Home Hub devices
You can do this with Google/Nest Home Hub, though honestly I’m more likely to use the interface built into the Google/Nest Home…
Given that the Google/Nest Home Hubs are Cast devices, if you can cast to a ChromeCast you can cast to those. I just tried Plex, and it does work, even if the display is a bit small for that.
