Nest image snapshot on Doorbell ring --> Google AI --> Alexa TTS
Example of sending a Nest doorbell-triggered webcam snapshot to Google AI for summarization. The image description response is announced over Alexa TTS.
alias: Doorbell Ring Google AI will describe
description: When doorbell rings, Google AI will summarize what it sees.
  - platform: device
    device_id: abc123
    domain: nest
    type: doorbell_chime
  - service: camera.snapshot
      filename: /media/nest/screenshot/front_door.jpg
      entity_id: camera.front_door
  - service: google_generative_ai_conversation.generate_content
      prompt: Very briefly describe the people in this image. Only mention people.
      image_filename: /media/nest/screenshot/front_door.jpg
    response_variable: generated_content
  - service: notify.alexa_media_tube
      message: "{{ generated_content.text }}"
  - service: notify.all_mobile_devices
      title: Doorbell ring
mode: single
ha notif
Hi, I’m a noob and just started with HA. I’ve two questions:
  • Should this code be put in configuration.yaml?
  • Is it possible to attach the picture to the notification message?
You can write the automation in the Automations section. The raw YAML of my automation is below. You will need to tinker for your specific setup.
Not sure about including an image in a device notification. Could be possible.
alias: Doorbell ring describe via Google AI
triggers:
  - device_id: YOUR_DOORBELL
    domain: nest
    trigger: device
conditions: []
actions:
  - data:
    action: camera.snapshot
  - data:
      filenames: /media/nest/screenshot/front_door.jpg
      prompt: briefly describe any people you see
    action: google_generative_ai_conversation.generate_content
  - data:
    action: notify.alexa_media_tube
  - data:
    action: notify.alexa_media_kip_s_echo
  - data:
    action: notify.all_mobile_devices
mode: single
Thanks for your code. I’ve manage to send notifcation via Telegram now.
Waking up an old one…
Did you manage to get an image from your Nest Doorbell?
I have similar as described above - but the image is created by the snapshot service (and sent out) is just black one.
Yes. This code handles taking the snapshot and saving…
actions:
  - data:
Hi , I found a solution for this. Link to the video on my channel below.
[Tutorial] Google Nest Doorbell Integration with Vision LLM
