I have added with success as it seems the intergration. But there are no devices? I have a nest e thermostat.
Check out the logs in configuration > logs and see if there are any error messages.
Could this have to with it?
Could not contact https://homegraph.googleapis.com/v1/devices:reportStateAndNotification
April 13, 2021, 8:09:14 PM – (ERROR) Google Assistant - message first occurred at April 13, 2021, 8:05:30 PM and shows up 12 times
2021-04-12 19:37:32 ERROR (MainThread) [homeassistant.components.nest] Configuration error: Subscription misconfigured. Expected subscriber_id to match ‘projects/./subscriptions/.’ but was ‘projects/home-assist-586fa/topics/hass_nest’
Hi @snhnic have a look at the guidance in the troubleshooting instructions in the integration documentation and see if that helps: Nest - Home Assistant – also check out the pubsub subscriber step #4 Enter topic manually
Let me know if that doesn’t help and i’m happy to explain in more detail if you have questions.
