Hey guys, I hope this is the right support room, but I am a complete noob who just today started to work with home assistant. I am trying to go through the nest integration and after doing everything while I’m getting to the last part of adding the nest integration and giving the google nest permission but there I’m getting an error and I don’t know what to do. The Error is Error 400: invalid_request.
if someone think that adding me to discord will make it easier to help me ( I can share screen and everything) this is my username Mr.President#1929
This means that it requires that your home assistant is set up with SSL so that when it redirects back it knows its securely passing the credential. This is a really high bar so as of 2021.12 this is no longer a requirement and we have a simpler way to integrate with Google! You can either wait for Saturday for the release, or install the beta and I can point you at the latest instructions.
Hi the new home assistant is released so check out new steps in Nest - Home Assistant as ssl urls are no longer required.
