Nest Integration Failing after a Restart
I restarted Home Assistant as I was working own some ZWave stuff. Now my Nest doesn’t connect.
Any ideas?
2021-01-28 14:34:14 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Configuration.yaml for nest
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 236, in async_setup
    result = await component.async_setup_entry(hass, self)  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/nest/__init__.py", line 173, in async_setup_entry
    await subscriber.start_async()
  File "/usr/local/lib/python3.8/site-packages/google_nest_sdm/google_nest_subscriber.py", line 132, in start_async
    creds = await self._auth.async_get_creds()
  File "/usr/src/homeassistant/homeassistant/components/nest/api.py", line 34, in async_get_creds
    token = await self.async_get_access_token()
  File "/usr/src/homeassistant/homeassistant/components/nest/api.py", line 28, in async_get_access_token
    await self._oauth_session.async_ensure_token_valid()
  File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 472, in async_ensure_token_valid
    new_token = await self.implementation.async_refresh_token(self.token)
  File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 84, in async_refresh_token
    new_token = await self._async_refresh_token(token)
  File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 175, in _async_refresh_token
    new_token = await self._token_request(
  File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 193, in _token_request
    resp = await session.post(self.token_url, data=data)
  File "/usr/local/lib/python3.8/site-packages/aiohttp/client.py", line 619, in _request
    break
  File "/usr/local/lib/python3.8/site-packages/aiohttp/helpers.py", line 656, in __exit__
    raise asyncio.TimeoutError from None
Timeout error… That usually means a network problem? But surprised that would only affect nest.
Are you running 2021.01 or newer? I think this code path has changed a bit so maybe upgrading will help.
Weird. I restarted it this morning and everything is fine. Must been something going on with my internet that caused the issue.
Thanks for responding.
