Last month I added the Nest integrations following all the instructions and steps for the SDM API and it works well but when I got forwarded to the URL for the the authorization step I only authorized the devices I wanted to show up in Home Assistant (Thermostat and only 2 of my the cameras).
I just bought and setup a new camera and it is not showing up in Home Assistant even after reloading the integration and restarting the server. I assume it is because I need to re-authorize and add permissions to the new camera, but, I am only forwarded to this URL during the setup of the Integration.
Is there any way to re-authorize and change the permissions to the devices without deleting and re-adding the integration? I looked everywhere in the Cloud Console and also I tried to build this URL myself but I’m probably doing something wrong because I get an error at the end after adding the permission to the new device (domain and code masked):
The way you do this is typically delete the integration then re-add it, and it will ask you to authorize all the devices again, including the new device, then it works. Does that work for you?
From the description it sounds like you somehow were reauthorizing and it didn’t work, but just wanted to confirm if you got there via deleting it first.
Thanks, actually what I did worked, after I used the URL I built above and authorizing the additional devices I just had to restart Home Assistant and the new devices showed up… sorry I forgot to update this thread.
Would be nice if there was a button in the integration to re-authorize so you can add / remove permissions / devices as needed without having to delete the integration.
Hi, I have an issue where I deleted 4 Nest cam (battery) that I sold from the Google Home App. Unfortunately they still appear in the HA Google Nest Integration. I checked the Partner Connections Manager and they do not show up there. I seem to have no way to delete them from the integration. Anyone have any ideas? It’s not really a big issue just like things nice and clean. Thanks
I apologise if this is in the wrong thread but I do not know where else to post this.
OMG THANK YOU!
I already went through the hassle of removing my credentials and trying to re-add them, but it kept failing for some reason and could not get any camera working again.
Did a quick restore from a backup, used your method and it worked like a charm!
