Hello!
I’m trying to install the Nest integration. The install is not working and it ends with a message saying: Aborted: The component is not configured. Please follow the documentation"…
I’m confused… I was never asked to configure something.
Any clue?
I think this means you may need to update the configuration.yaml
? Not sure. Are you following the instructions at https://www.home-assistant.io/integrations/nest/#device-access-registration ?
In configuration.yaml
You need to insert the nest section:
nest:
client_id: ***
client_secret: ***
project_id: ***
subscriber_id: ***
Where to find each of those.is nicely coved in the nest integration docs. There’s a step by step guide as quite a lot of setting up needed in the Google cloud console
