I’ve been running Home Assistant for a few years and my Nest Thermostat was one of the first devices I’ve added.
Just added these 2 lines in my yaml and it has been working like a charm since then: nest:
client_id: !secret nest_clientid*
client_secret: !secret nest_clientpass*
Today I was rummaging about in some settings and added a simple switch to do something entirely unrelated and restarted Home Assistant.
since then… Nest is unavailable. No errors when HASS started. The only error comes when I try to reload the integration:
AttributeError: ‘NestLegacyDevice’ object has no attribute ‘get’
I’ve heard of some things that Google wants you to migrate, but I reeeaaallly don’t want to migrate my account to Google and have to use very tedious methods to create cloud projects etc etc etc.
Is there a bug that has slipped in the latest version of hass?
Home Assistant 2022.10.3
Supervisor 2022.10.0
Operating System 9.2
Frontend 20221010.0 - latest
I know that the old works with nest integration was planned to be removed since the start of the year (2022.02 blog indicated removal will be in 2022.5), but it seems weird for it to disappear on a dot release not on main release.
I thought that was for google nest API, not the legacy “works with nest” which I (and I thought also you) are using. Still the writing is on the wall and I need to migrate to google account…
Logger: homeassistant.util.async_
Source: util/async_.py:180
First occurred: 8:30:03 AM (2 occurrences)
Last logged: 8:30:04 AM
Detected blocking call to putrequest inside the event loop. This is causing stability issues. Please report issue for nest doing blocking calls at homeassistant/components/nest/legacy/init.py, line 320: for structure in self.nest.structures:
Yup… Still on legacy…
Don’t want to pay extra to be able to access my locally installed hardware.
Also getting these:
Im resigned to the WWN integration being removed and having to pay $5 to use the google SDM API.
I would just have hoped it would be removed in a more managed manner than a broken dot release with no breaking change notice in the 2022.10.x release notes.
I put everything back the way it was. And suddenly like magic, a few hours later it came back online…
This gives me a little more time to find a substitute or find a creditcard.
The issue is not only with Nest but it actually has to do with Google deprecating their OAuth2 identity authentication method. There is this document from google explaining that the old OAuth method will stop working entirely after October 3rd, 2022.
Both Google home integration and Nest integration will start working like before if you completely remove it and create a new google/nest application project from the beginning as currently described in the documentation. Do not try to do anything with the old setup. I know it’s a hassle but the quickest and easiest is if you completely remove it and setup a new integration from the beggining. Do not use the old project name. Do a new clean setup. They both will quickly work without a problem.
