New nest integration gives error:
I am running from public url but it redirects to local IP which i cannot add to authorized redirect uri, but have added the public URL.
Configuration.yaml:
http:
external_url: smarthome2.xx.xx
internal_url: 192.168.68.xxx:8123
Do you maybe know what’s going wrong @allenporter ?
thanks
try removing the internal_url from your HA? reboot do the same, add it again
maybe this is a workaround for you untill its fixed/investigated
Thank you,
I tried but unfortunately, it still redirects to the local IP with the config integration. It’s really strange. Is there a way to force it?
maybe its still in your cache? i also see you have added www.google.be in redirecturls ? thats not needed?
i only have 1 url there , my public HA url
That url was for testing if the API works, and that does.
dinan5
(Dinan5)
November 14, 2020, 7:12pm
6
Perform the same function from outside your home network. It should work.
I think it s caused by my reverse proxy rewrite thing in iis. For now I added the port and started using duckdns. that works.
Of course i tried the url from my 4g mobiel network also.tnks anyway
