I have tried setting up the nest integration a few times now and every time changes are not being added to the topic/subscription. If I update the temperature from homeassistant, the temp changes on the thermostat but then in homeassistant the temp goes back to what was previously set. If I reload the integration the values sync back up.
Logs do not show any errors even with debug mode turned on. I manually made a call to the device endpoint and that also did not work. If I view messages within the google console no messages appear even when changing temps on the thermostat.
I dont see any permissions missing within PCM or the google home app everything seems to be correct. Any one have any ideas on what to check?
Thanks!
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.5.2",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.11",
"docker": true,
"arch": "aarch64",
"timezone": "America/New_York",
"os_name": "Linux",
"os_version": "6.1.21-v8",
"supervisor": "2023.04.1",
"host_os": "Home Assistant OS 10.1",
"docker_version": "23.0.3",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"coway": {
"version": "0.1.9",
"requirements": [
"cowayaio==0.1.7"
"hacs": {
"version": "1.32.1",
"requirements": [
"aiogithubapi>=22.10.1"
"integration_manifest": {
"domain": "nest",
"name": "Google Nest",
"after_dependencies": [
"media_source"
"codeowners": [
"@allenporter"
"config_flow": true,
"dependencies": [
"ffmpeg",
"http",
"application_credentials"
"dhcp": [
"macaddress": "18B430*"
"macaddress": "641666*"
"macaddress": "D8EB46*"
"documentation": "https://www.home-assistant.io/integrations/nest",
"iot_class": "cloud_push",
"loggers": [
"google_nest_sdm",
"nest"
"quality_scale": "platinum",
"requirements": [
"python-nest==4.2.0",
"google-nest-sdm==2.2.4"
"is_built_in": true
"data": {
"subscriber": {
"create_subscription.attempt": 1,
"start": 2,
"stop": 1
"devices": [
"data": {
"name": "**REDACTED**",
"type": "sdm.devices.types.THERMOSTAT",
"assignee": "**REDACTED**",
"traits": {
"sdm.devices.traits.Info": {
"customName": "**REDACTED**"
"sdm.devices.traits.Humidity": {
"ambientHumidityPercent": 49
"sdm.devices.traits.Connectivity": {
"status": "ONLINE"
"sdm.devices.traits.Fan": {
"timerMode": "OFF"
"sdm.devices.traits.ThermostatMode": {
"mode": "OFF",
"availableModes": [
"HEAT",
"COOL",
"HEATCOOL",
"OFF"
"sdm.devices.traits.ThermostatEco": {
"availableModes": [
"OFF",
"MANUAL_ECO"
"mode": "OFF",
"heatCelsius": 15.531998,
"coolCelsius": 25.334091
"sdm.devices.traits.ThermostatHvac": {
"status": "OFF"
"sdm.devices.traits.Settings": {
"temperatureScale": "FAHRENHEIT"
"sdm.devices.traits.ThermostatTemperatureSetpoint": {},
"sdm.devices.traits.Temperature": {
"ambientTemperatureCelsius": 24.159988
"parentRelations": [
"parent": "**REDACTED**",
"displayName": "**REDACTED**"
2023-05-08 11:09:20.515 DEBUG (MainThread) [homeassistant.components.nest] Stopping nest subscriber
2023-05-08 11:09:20.532 INFO (Thread-ConsumeBidirectionalStream) [google.api_core.bidi] Thread-ConsumeBidirectionalStream exiting
2023-05-08 11:09:21.308 DEBUG (ThreadPoolExecutor-2_0) [google_nest_sdm.google_nest_subscriber] Subscriber 'projects/<REMOVED>/subscriptions/<REMOVED>' configured on topic 'projects/sdm-prod/topics/<REMOVED>'
2023-05-08 11:09:21.323 DEBUG (MainThread) [google_nest_sdm.google_nest_subscriber] Starting background watchdog thread
2023-05-08 11:09:21.323 DEBUG (MainThread) [google_nest_sdm.auth] request[get]=https://smartdevicemanagement.googleapis.com/v1/enterprises/<REMOVED>/structures
2023-05-08 11:09:21.733 DEBUG (MainThread) [google_nest_sdm.auth] response={'structures': [{'name': 'enterprises/<REMOVED>/structures/<REMOVED>', 'traits': {'sdm.structures.traits.Info': {'customName': 'Huntington'}}}]}
2023-05-08 11:09:21.734 DEBUG (MainThread) [google_nest_sdm.auth] request[get]=https://smartdevicemanagement.googleapis.com/v1/enterprises/<REMOVED>/devices
2023-05-08 11:09:22.303 DEBUG (MainThread) [google_nest_sdm.auth] response={'devices': [{'name': 'enterprises/<REMOVED>/devices/AVPHwEundERve_bBDZHlNVpB6O_ngPNgARQsY1pSvra-crNyzmiUfJEqWHORz05VZQaSfYhtC0D_Orkb3MeL-Au-f9lM_Q', 'type': 'sdm.devices.types.THERMOSTAT', 'assignee': 'enterprises/<REMOVED>/structures/<REMOVED>/rooms/<REMOVED>', 'traits': {'sdm.devices.traits.Info': {'customName': ''}, 'sdm.devices.traits.Humidity': {'ambientHumidityPercent': 49}, 'sdm.devices.traits.Connectivity': {'status': 'ONLINE'}, 'sdm.devices.traits.Fan': {'timerMode': 'OFF'}, 'sdm.devices.traits.ThermostatMode': {'mode': 'OFF', 'availableModes': ['HEAT', 'COOL', 'HEATCOOL', 'OFF']}, 'sdm.devices.traits.ThermostatEco': {'availableModes': ['OFF', 'MANUAL_ECO'], 'mode': 'OFF', 'heatCelsius': 15.531998, 'coolCelsius': 25.334091}, 'sdm.devices.traits.ThermostatHvac': {'status': 'OFF'}, 'sdm.devices.traits.Settings': {'temperatureScale': 'FAHRENHEIT'}, 'sdm.devices.traits.ThermostatTemperatureSetpoint': {}, 'sdm.devices.traits.Temperature': {'ambientTemperatureCelsius': 24.159988}}, 'parentRelations': [{'parent': 'enterprises/<REMOVED>/structures/<REMOVED>/rooms/<REMOVED>', 'displayName': 'Living Room'}]}]}
2023-05-08 11:09:22.305 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.nest
2023-05-08 11:09:22.306 INFO (MainThread) [homeassistant.components.camera] Setting up camera.nest
2023-05-08 11:09:22.306 INFO (MainThread) [homeassistant.components.climate] Setting up climate.nest
