Device: Home Assistant Yellow
OS Version: 9.4
Core Version: 2023.1.7
I’m trying to load the nest integration using the old “Works with Nest API” by entering the details in the configuration.yaml file. I’ve entered the correct client_id and client_secret just like in my old installation, but it does not load the integration or any entities. It just shows the auto-discover Nest card still.
nest:
client_id: clientid
client_secret: secret
I set the logging to debug, and I could only find a few mentions of the nest component, but no errors:
2023-01-25 14:03:39.634 DEBUG (MainThread) [homeassistant.helpers.translation] Cache miss for en: (lists like 300 integrations including nest)
2023-01-25 14:03:42.065 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {'automation', 'auth', 'scene', 'input_datetime', 'script', 'alexa', 'image_upload', 'ffmpeg', 'onboarding', 'openweathermap', 'person', 'config', 'harmony', 'application_credentials', 'lovelace', 'homeassistant_alerts', 'schedule', 'blueprint', 'system_health', 'sonos', 'counter', 'energy', 'analytics', 'trace', 'zone', 'timer', 'homeassistant_hardware', 'map', 'logbook', 'diagnostics', 'default_config', 'input_text', 'sun', 'lifx', 'device_automation', 'input_boolean', 'nest', 'input_number', 'media_source', 'my', 'history', 'search', 'homeassistant_yellow', 'smartthings', 'input_select', 'upnp', 'repairs', 'remote', 'file_upload', 'mobile_app', 'tag', 'litterrobot', 'switch', 'hardware', 'met', 'input_button', 'radio_browser', 'plex'}
2023-01-25 14:03:42.150 DEBUG (MainThread) [homeassistant.setup] Dependency nest will wait for dependencies ['ffmpeg', 'application_credentials']
2023-01-25 14:03:42.150 DEBUG (MainThread) [homeassistant.setup] Dependency nest will wait for after dependencies ['media_source']
2023-01-25 14:03:46.205 DEBUG (MainThread) [homeassistant.bootstrap] Running timeout Zones: {'sonos': <sonos: 0 / 1>, 'default_config': <default_config: 0 / 1>, 'upnp': <upnp: 0 / 1>, 'litterrobot': <litterrobot: 0 / 1>, 'met': <met: 0 / 1>, 'radio_browser': <radio_browser: 0 / 1>, 'plex': <plex: 0 / 1>, 'sensor': <sensor: 1 / 0>, 'harmony': <harmony: 0 / 1>, 'mobile_app': <mobile_app: 0 / 1>, 'smartthings': <smartthings: 1 / 0>, 'nest': <nest: 0 / 1>}
2023-01-25 14:03:48.239 INFO (MainThread) [homeassistant.setup] Setting up nest
2023-01-25 14:03:48.242 INFO (MainThread) [homeassistant.setup] Setup of domain nest took 0.0 seconds
2023-01-25 14:03:48.272 DEBUG (MainThread) [homeassistant.bootstrap] Integration remaining: {'smartthings': 2.11059, 'upnp': 1.972626, 'litterrobot': 1.715774, 'met': 1.703854, 'radio_browser': 1.478678, 'plex': 1.243727, 'harmony': 1.139134, 'mobile_app': 1.016219, 'nest': 0.032652}
It’s worth noting that if I load the old server up, it can still see and control the Nest integration just fine, though it is running on Core version 2022.8.7
I did not restore a backup to setup the new HA on the Yellow because I had a large number of things all janked up on the old one and wanted to start clean.
