Hi, after last upgrade my nest camera doesn’t work anymore in HA. In the log I read “unable to find service nest/set_mode”. Is there known problem with this release?
Checking in to report the same issue. Started seeing this error lately
Log Details (WARNING)
Unable to find service nest/set_mode
Running 0.83.3.
p.s. My camera DOES work.
Check the documentation https://www.home-assistant.io/components/nest/. It seems that at a certain point the commands to set the modes has been changed. After fixing the commands all has worked
