Nest No Longer Controllable?
I have been having more and more trouble controlling my Nest thermostat. I haven’t upgraded past 0.95.2, so it isn’t a matter of the new climate format. And I have had a developer account for years, so I should be “grandfathered” into the api. But I am having trouble setting mode and temperatures both from the frontend and through node-red. Anyone experience this as well?
I have upgraded to the latest version 0.97.2 and have a Nest. I however have not had any issues at all. I’m not using node Red, but I am able to set temperature without issues.
Are you getting any errors?
Here some screenshots from my integration today:
No errors in the log or anything, the services just don’t seem to be working. For example, I’ll try and set the thermostat to eco, both manually and through NR, and the thermostat will remain on cool.
Hmm very strange and as you do, it doesn’t give any errors in the log? Is information on the climate card accurate (eg room temperature?).
Yeah it’s accurate, and it will update if I change something from the app. But, for example, if I bring up the more info card, and change to Eco mode, the frontend nor the Nest app update. But if I go back into the more info card, it still shows Eco mode as the selected mode
