Nest on NUC Won't Validate
I’m running hassio in Docker on Ubuntu on an Intel NUC, and I am having issues with connecting to Nest. I have my client_id and my client_secret in my configuration. But when I go to configure my nest from the integrations page, I get an “Internal error validating code.” This is what appears in the log
 Log Details (ERROR)
Sun Dec 09 2018 20:50:29 GMT-0500 (Eastern Standard Time)
Unexpected error resolving code
  File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 159, in _new_conn
    (self._dns_host, self.port), self.timeout, **extra_kw)
  File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 57, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/local/lib/python3.6/socket.py", line 745, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen
    chunked=chunked)
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 343, in _make_request
    self._validate_conn(conn)
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn
    conn.connect()
  File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 301, in connect
    conn = self._new_conn()
  File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 168, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7f768944a198>: Failed to establish a new connection: [Errno -3] Try again
  File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 449, in send
    timeout=timeout
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 398, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='api.home.nest.com', port=443): Max retries exceeded with url: /oauth2/access_token (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f768944a198>: Failed to establish a new connection: [Errno -3] Try again',))
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/nest/config_flow.py", line 105, in async_step_link
    tokens = await flow['convert_code'](user_input['code'])
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/nest/local_auth.py", line 39, in resolve_auth_code
    await hass.async_add_job(auth.login)
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/local/lib/python3.6/site-packages/nest/nest.py", line 175, in login
    response = post(ACCESS_TOKEN_URL, data=data, headers=headers)
  File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 116, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 60, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 533, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 646, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 516, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='api.home.nest.com', port=443): Max retries exceeded with url: /oauth2/access_token (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f768944a198>: Failed to establish a new connection: [Errno -3] Try again',))
I’m also having issues with my MQTT, WUnderground, Telegram, basically anything where Home Assistant has to talk to something that’s not itself. But the Nest is the instance where I can get the clearest log. Is there a way I’m supposed to open ports on Docker or something that I’m missing?
Can the Docker container reach the internet? It looks like it’s not able to connect.
It can. When I ping Google I get no packet loss.
Same issue over here. I have my Hassio installed on a rasprberry pi 3 but i am unanble to configure nest on my home assistant. I get the message internal error. I have read that it could be related to my network settings but I did not manage to fix it.
Do you have the same errors in your log that I’m getting?
I ended up switching from Ubuntu Desktop to Ubuntu Server and everything is running as expected.
