Nest Protect not reporting
Morning All,
I have Nest Protects in my house and I have enabled the nest component in HASS with my id and secret and then via the UI configured nest entered the pin and both my protects show up in the UI with Online, Smoke, CO2 and battery sensors however when the alarm is triggered either warning or alarm it doesn’t show up in HASS yet the other alarm gets the alert so does both mine and the wifes phone so its obviously sending out the warning/alarm signals so why isn’t HASS getting these?
Any ideas?
Kind Regards,
Max
Please try again with 0.71 beta or wait 0.71 released.
Hi awarecan. Upgraded to 0.71 today then set my protect off for 15 seconds silenced it and then about another 20 seconds it said smoke cleared but still in HASS says the protect smoke sensor is OK updated 42 minutes ago (I set it off about 20 mins ago).
The online sensor says connected.
Are you doing manual test? Press the button on device, or use Check Up function on App?
I don’t have Nest Protect, but manual test doesn’t trigger real sensor at least in my simulator environment.
no I’m setting the alarm off for real. The alert comes through pm the app absolutely fine and it triggers the other protect I have so I know it’s connected and reporting back to nest perfectly fine just doesnt go through to HASS
Interesting, can you help me do that again and grab some logs? In your configuration.yml add following to enable the logs
logger:
  logs:
    homeassistant.components.nest: debug
    homeassistant.components.sensor.nest: debug
    sseclient: debug
Sure I’m just heading out for a bike ride and will do that a bit later.
Good Morning,
Sorry bit slow to do this. Here are the logs: https://hastebin.com/dematagode.vbs
I set the alarm of at 06.43 this morning the time is currently 06.47 and the sensor on HASS is showing OK last updated 7 minutes ago. If you hover over the OK bar it shows:
OK
11 June 2018, 06:48
12 June 2018, 06:48
The 7 minutes ago would of been when HASS rebooted for config changes.
from the log I can read that the first update event received on 2018-06-12 06:43:02, and it keep received update till 06:43:05, then after 20 seconds, from 06:43:23 to 06:43:26, there was another wave of update events.
So it looks like network is ok, the upstream library works well. Did you ever get Nest Protect works in your HA before/after upgrade?
No its never worked only ever reports ok.
Ok out of the blue randomly is reported whe I accidentally set it off and the automations I had setup ran so thats great news. Not sure whats changed though.
Got my protect up and running today, if I understand correctly from the community posts, there is not a way to really test the states? OK, warning, emergency?
The test button on the nest “works” but does not report back to HA.
Does anyone have way to test the various states? I’d hate for my house on fire to be the 1st time I test my automations, haha
Manual test will not report to Nest API, therefore no report in HA.
light a match under
